Which High Octane Fuel Should I Mix in my car?
Originally Posted by SMG353' post='626721' date='Jul 17 2008, 03:18 PM
Go for it.
First time around to see how yoru car react, go with 3 gallon, about $30, adn fill the rest with 93 oct.
Just to see how your car handles it. See if you like it, I am sure you will.
Then the next step would be 1/2 with 110 and half 93.
The question is, can it handle 116 oct. mixed with 93?
Anyone know
Anyone know
My Ride: 04' 545i SMG , Oriental Blue, Congiac Leather Interior, Nav., Park Assist, Logic 7, Sports Pkg, Cross drilled slotted rotors, ceramic pads, SS Brake lines, free flow air filter and a supercharger (coming soon)etc.....all the good stuff
Originally Posted by C's Bimmer' post='626723' date='Jul 17 2008, 03:19 PM
I'm going with all 116 and blowing my engine out. screw it! I'm going back to the future bitches!
lmao!!!!!
At least when you bring it back it's under warrenty. Just make sure to tell them you dont' know what happened..
My Ride: 2009 Ford F-250 Harley Davidson Edition
6.4L OHV Power Stroke Turbo Diesel V8 (350hp/650lbft)
Blue Flame Package
Dual Alternators
Touch Screen Navigation + DVD Player
Uplifter Switches
Trailer Brake Controller
Traction Control
Rapid Heat Supplemental Cab Heater
Rear View Camera
Power Slide Moonroof
My Ride: '05 545 Titanium Silver, Black Leather - Nav, Logic 7, Cold weather.
Mods:
Carbon filter removed.
M5 iDrive knob.
Umnitza license plate LEDs.
MP3
40% 3M tint
ACS Anti-Roll(sway) bars
RPI Scoop
G-tech Pro RR
CF Roundels
CF Wheel caps
Go for it.
Anyone know
Enjoy the smooth shifting and the quick acceleration......
Just think, your actually cleannig yoru injectors at the same time
Anyone know
Anyone have some race fuel and a dyno?
Originally Posted by Brit_in_NJ' post='626741' date='Jul 17 2008, 03:42 PM
I thought the theory was that the octane rating was a rating of resistance to ignition. You can trigger ignition when compression is higher in the cylinder releasing more energy, the fuel itself does not contain any more energy than a lower octane fuel. If it's true that the ECU will detune itself to run on lower octane fuel then the reverse might also be true that it can tune itself for a higher octane but how far will it go? It seems that the worst that can happen is that you are just waisting money on a higher octane than the engine can use. All thats happening if you use an octane too high for the ECU is that its triggering ignition before it's peek compression. This is not the same as using lower octane fuel that auto detonates before the ECU can trigger the sparkplug which causes knocking and can lead to engine damage. The answer would probably be to mix octanes until you get to a peek performance from the ECU
Mods:
M5 iDrive knob.
MP3
40% 3M tint
RPI Scoop
G-tech Pro RR
CF Roundels
CF Wheel caps
Originally Posted by C's Bimmer' post='626743' date='Jul 17 2008, 03:44 PM
Speaking of remap, when are you getting your 545 remapped richard? You were the lucky winner of that prize at the meet. Hurry!
Originally Posted by Brit_in_NJ' post='626749' date='Jul 17 2008, 03:50 PM
I was hoping this week or next, I might try to get some 116 after that I was hoping to test it out on the Bear mountain roads
You got a place in NJ that sells 116?......I don't know if Englishtown does?
I know of a Sunoco here that does it's about $90 for 5 gallons
Mods:
M5 iDrive knob.
MP3
40% 3M tint
RPI Scoop
G-tech Pro RR
CF Roundels
CF Wheel caps
chadillac2000
42
09-13-2017 11:15 AM
thesalboy
04-08-2015 09:13 AM
