High Beam Color
Old Jan 31, 2011 | 07:53 AM
Randuin's Avatar
I have a 2007 550i and it already has DRL but it seems to use an under-volted high beam for it? And it's all yellow and stuff so I was wondering if I could swap it out for different Xenon bulbs but I'm not sure which ones to use.
Old Feb 2, 2011 | 05:33 AM
Sluis530's Avatar
My Ride: 2004 530i
To my knowledge you can swap your stock high beam bulb with a aftermarket xenon bulb.. email member -- John@motorcepts.com - he has helped me with all my lighting and is pretty much a guru at what you need..
Old Feb 2, 2011 | 08:33 AM
healthservices's Avatar
I think the only option is colored bulbs
Old Feb 2, 2011 | 08:35 AM
John@Motorcepts's Avatar
Banned
My Ride: A Car
if u run HIDs in the high beam, it's a waste of money. You also need to run a gold relay for that. I dont recommend it. You can get the LED bulbs but you LOSE the flashing high beam brightness. You still have stock bixenons when you push the lever though. IMHO, the BEST way is to turn off the daytime running lights for the cleanest look. Do not get colored bulbs. They are dangerous since they run on high wattage and may damage the harnesses or worse housing.
ucsbwsr
26
Feb 26, 2025 08:22 AM
rkilpa
Aug 4, 2015 06:14 PM
Bank$hot530
Jul 21, 2015 07:44 AM
Bank$hot530
Jul 18, 2015 02:25 PM
PelicanParts.com
Jul 13, 2015 03:02 PM
