HIFI OEM subs and what type of amp do I need
So I just spent about 3 hours reading posts learning all about our audio systems in our cars-was a good read but I am very not technical so I will take this to a car audio shop.
I dont want them to have to rip seats out etc to find what kind of subs are there. Is there info from the stock (non L7) subs that I need to know in order to tell them-for example will they need info about the stock subs in order to choose the proper amp?
Like what power amp is appropriate to drive the stock HIFI subs under the seats?
I guess any technical data that would be needed to tell to an audio shop in order to get the best equipment-since I dont know what I am doing!
I would not add an aftermarket amp to power the stock subs, you are probably better off adding and amp and additional subs in the trunk. That is what I did. It was easier and less expensive. The stock "subs" are really more like mid-bass speakers and will never produce the low freqs very well. They can make a decent mid bass with a different sub setup in the trunk. Just MHO. Good luck.
Actually reading through virtually everypost I could find on here regarding upgrading audi-the vast majority was to NOT put them in the trunk due to the fact our trunks are so well sealed that you do not get the bass through into the car.
I also do not want a lot of low base-I like hte mid range base the 8 inch OEM ones give-its just at louder levels it gets bad-which I need more power to them so I can keep the bass control down on idrive, play it loud and use the amp power to control the base independantly with enough power.
Many recomended this-I just need to have an answer to my question not advice one other options
My Ride: 2005 525i, 6spd manual, Premium pkg, Cold Weather pkg
![W00t](https://5series.net/forums/images/smilies/imported/w00t.gif)
If you want mid-range/hard hitting bass, go with 10's. You're right, our trunks are very well sealed. That's why I went with two.
I guess I will re-phrase-I have already decided to start with the amp based on messages I read on here that just doing that was signifigantly better and I already like my basic HIFI system. All I need to know is there some piece of info about the 8 inch subs under the seats that the installer will have to know in order to choose the right amp
incoherent
04-15-2015 04:48 PM
bruce_miranda
04-15-2015 03:25 AM
