Help on tire offset
Old Nov 16, 2006 | 07:21 AM
CVTBenhogan's Avatar
My Ride: 2006 BMW 550i "Ben Hogan's 5 Iron" SilverGrey/Black Sport, L7, NAV, CW, AS, Split FR 2003 Audi A4 3.0 CVT "Part of the Moniker" Silver/Ebony, Prem, CW, Star 17s
I really like the new 18s on the 335 coupe, type 189. Saw replicas that resemble these but meant to fit the 3 series. the bolt pattern is 5x120 and the offset is 35mm. I assume the E60 bolt and hub setup is the same but the offset is 20mm. Can these fit with or without a spacer? Any try something like this?
CVT Benhogan
Old Nov 16, 2006 | 10:55 AM
dgjk's Avatar
Not sure about the spacers. Offset for a non xi e60 is 20mm. If you add a 20mm spacer it should chage the offset to 15mm and they should fit. I drew some pictures for myslef to prove this and it should work. However, no one has ever confirmed that the hub is the same. I read a post here about 3 series rims not fitting around the brakes on the e60. If you try it let me know because I have an xi and if I can get 3 series wheels on it I would have many more choices at a lower cost
Old Nov 19, 2006 | 04:18 AM
olli_535d's Avatar
My Ride: 535d Sport, carbon black, media pack, visibility pack, grey leather, heated seats, sun protection glass, voice control, Eibach ProKit, 19" 166 style wheels, e-maps ECU remap to 325hp and 640NM, top speed limiter removed
The largest non M5 brakes are on the 535d and the V8's.
Both only require 17" rims to clear the brakes, so 18's will clear them in any case.
By using 20mm spacers they will fit fine, as the other parameters are the same. From 20mm upwards I would use only hub mounted spacers. That way you can use the existing bolts and they would give me a better feel regards sturdiness.
Old Nov 20, 2006 | 08:52 PM
monacobmw's Avatar
I may be selling my 20mm spacers when I get my new OEM 19" #166s. I will need a 12mm spacer.
My old wheels were ET32, and 20mm did very well. I am sure that 20mm works well with ET35 as well.
Old Nov 20, 2006 | 11:20 PM
arcleid's Avatar
My Ride: 2006 525i Silver Gray/Gray Dakota Leather | Steptronic | Cold Weather | Xenon | Premium Package Modifications: M Aero Kit | Carbon Fiber Kidney Grill | K&N Air Filter | Charcoal Filter Removed | Radenergie R10 Silver 20" soon | kW coilover V3 | SprintBooster soon | M5 trunk finisher Next planned mods: ?Hamann quad exhaust + Hamann quad rear diffuser + Hamann Front Lip?
Do the 3 series wheels have the same fitment as M3?
Old Nov 20, 2006 | 11:37 PM
xexyus's Avatar
My Ride: 05 530 Titanium Silver/Sexy black
I wouldnt trust it, the spacer would be huge thus possibly causing vibration. Buy a lower offset wheel
Old Nov 21, 2006 | 07:23 AM
monacobmw's Avatar
I have my 20mm spacer on my OEM 17" wheels. No vibration problem at all (and I can assure you that I am sensitive to vibration--see my 100 or so other posts). I think vibration has to do with the fit of tire to hub. If you have a good quality spacer (H&R), the fit will be no different than a 12mm spacer.
Best regards,
Richard
Kasmo
Jul 8, 2016 08:03 PM
BurtonSnol3order
May 7, 2015 08:35 PM
asinner
May 6, 2015 06:03 PM
Kasmo
Apr 12, 2015 02:38 PM
Gizmo
Lounge
Jul 16, 2004 05:15 PM
