help with rear sun shade door panel retrofit
My Ride: coilvers retrofits
Model Year: 2001 and 2011
i came across black sport interior, and have almost everything in, but the rear door panels i believe require a different weather stripping for it to snap in? can anyone confirm this? as you can see from the highlighted area in the photo, the sun shade doesn't seem to allow for metal clips to snap in place unlike the old door panel.
can anyone tell me if the inner weather strip is all i would need (besides the obvious hooks, would i need a complete trim or can i just but the hooks by themselves?)
im not too worried about the hooks, as i dont care that much for the shades, but mostly to get this panel on as im driving without them, and for the rear shade, i have the motor and deck and thanks to a DIY on here i think i have the wiring down for it to work.
any quick help highly appreciated as i can source where to buy the parts.
The shade won't clip in?
Maybe its not lined up, or you have the right shade on the left door panel?
The strip should be the same with or with out the shades. There is only 1 part number for each side.
http://bmwfans.info/parts/catalog/E6...herstrip_rear/
alright guys, figured it out, and i feel a bit like a dummy missing the obvious, but for anyone in the future...
you just simply remove the metal clips! the shade is made to form around the weather strip, and the weather strips with the strips next to the smaller window do snap in place..easy as that!.
thanks mike for the quick reply!
My Ride: 04 545i sport, stick, L7, sat, nav. Charcoal/ runflat/ cdv delete.
Suede headliner/ trunk, 3 way front speakers, four 8" subs in rear shelf, ACM, iPod dock in ash tray using gateway 500 with MP3 text and video on screen, MRTM aluminum pedals/ door pins, 10 farad cap, sound processor, line conditioner, 2 amps ( 4x100 and 2x200)
The metal clips you removed actually come in 3 different styles.
1- standard door panel
2- sunshade door panel
3- long clip style 3 ( not sure the application but I have some in stock )
You have to change the 4 clips in that rubber seal in order to lock in and support the slider.
quantity 8 part number 51-42-7-071-120
thanks for the reply, but i figured it out that day i posted, i was able to get the seal with the clips from the donor car so when i swapped it, it had the smaller clips.
Stormcrow
12-01-2019 03:09 AM
TexaZ3
05-06-2015 10:54 AM
