Help identifying what tires I need?
I picked up some replica M5 rims recently. I got a great deal on them and they are fine appearance wise. One problem however is that they are bronze in color and I plan to have them powder coated black. Another issue I am having is I can't find what tires I need for the rims. The seller told me they are 19.5" rims but it seems like 19.5" is not a common size at all. Anyway to find out what kind of tires I can run? I was reading around apparently several BMW rims that are actually 20" are said to as being 19.5".
A bit confused.
A bit confused.
My Ride: 2008 535xi Platinum Gray, Black Dakota Leather, Sport Pkg
Ummm, really? If I were you, I'd figure out what size my rims are. Got a tape measurer? They're most likely 19", but you need to know for sure. You also need to know your width. Once you have this valuable information, may I suggest tire tirerack.com to determine the correct tire size?
You'll spend as much getting a quality paint job on those as it would cost to buy brand new replicas.
Sell them and start over.
http://www.modbargains.com/BMW-M5-Wh...atte-Black.htm
assuming these are reps, they shouldn't be that expensive in the first place. Why not turn it into a project and paint it yourself. If you prep it well enough, a good rattle can paint job will turn out very nice.
I haven't encountered any 19.5" rims before but did read about it at the other forum though and Tirerack do sell 19.5" tires.
