has anyone cut the resonator out of a e60 535i
My Ride: 2008 535i white/black sport,prm,navi,cold weather
i was thing of cutting out my resonator out of my car has anyone done it on a 535i if so how does it sound, also will u lose power
My Ride: See sig :)
theres an intresting mod for the 335i's where you disconnect some plug in the back, and it opens up the valve or something make the cars exhaust note ALOT better sounding... checkout e90post for details, wonder if 535 would be similar...
Originally Posted by jcool10181' post='656845' date='Aug 28 2008, 10:54 PM
That'll be the golf tee mod. Not sure if this is applicable to the 535i. Can anyone chime in?
On the 535i, I think there is only one muffler with 2 exhaust tips (I'm probably wrong). Hence, no butterfly valve.
On the other hand, a resonator is a preforated core straight through exhaust component used (engineered) to eliminate or reduce certain frequency sound at certain engine rpm (usually around the 90 hz frequency range and 1500-2200 rpm). Removing the resonator will not give you a more "aggressive sound" but it will give you more "droning." If you want a more aggressive sound (and some droning my accompany it depending on your setup), you need to work on replacing the rear muffler.
My Ride: stock non-sport alpine white '04 530i
