H&R Spring Issues
I have a 2005 530i non-sport which has H&R sport springs installed and 20 inch wheels with a 245/35/20 front and a 275/30/20 in rear I have rubbing issues in the front when turn up a slight incline on the left and right side where it pulls the fender, I just had alignment and Iam running a negative camber of -1.0 up front and still RUBS!???????????
ANY FEEDBACK WOULD BE GREAT!!!!!!!!!!!!
Thanks
Thanks
Sounds like your front offset is a bit too aggressive. What is the off set and how wide are your front and rear rims?
My Ride: carbonized MB coupe
get fitted/pro spacers H&R or from the wheelmaker that you have, are they replicas?
i have 19" and lowered like hell with 245 at the front, with Breyton spacers, no rubbing at all
good luck
good luck
Originally Posted by monsterj34' post='1000502' date='Sep 7 2009, 10:54 AM
i have a same issue...
only solution.... coilovers
timmay77
11-17-2023 07:22 PM
DetailersDomain
Detailing Forum
03-24-2015 05:25 AM
