Got my white LED plate lights working without warning triangle!
Old 07-24-2006, 08:03 PM
neoenvision's Avatar
Finally got the LED plate lights working , added the resisters and take away the warning triangle
was easier than i thought
Attached Thumbnails Got my white LED plate lights working without warning triangle!&#3-ssl20416.jpg   Got my white LED plate lights working without warning triangle!&#3-ssl20423.jpg   Got my white LED plate lights working without warning triangle!&#3-ssl20445.jpg   Got my white LED plate lights working without warning triangle!&#3-ssl20446.jpg   Got my white LED plate lights working without warning triangle!&#3-ssl20428.jpg
Old 07-24-2006, 08:05 PM
and a funny picture i took on the road the other day ........
Attached Thumbnails Got my white LED plate lights working without warning triangle!&#3-ssl20403.jpg
Old 07-24-2006, 09:09 PM
mlist84's Avatar
do you mind provide us with LED and resistor type? and, how did you put the resistor? Thanks.
btw, your car is really hot especially with the white LED!
Old 07-24-2006, 09:59 PM
50 ohm 10w (DO NOT BUY A WRONG ONE, I tried a 100ohm before and it burned my fuse)
check out the following link, the picture is wrong tho, it should say 50 ohm 10W on the resister
http://www.radioshack.com/product/index.js...rentPage=search
the LED is 39mm festoon with 9 LEDs
http://autolumination.com/festoon.htm
Old 07-24-2006, 10:07 PM
blinkme_210's Avatar
My Ride: '06 530xi
Care to write up a little DIY guide?
Old 07-24-2006, 10:45 PM
it's actually very simple
read the manual and open the cover of the plate lights
remove the original bulbs ( if you know how to remove AA batteries from a toy , you'll know how to remove the bulbs )
you should see a hole on the metal pieces on both side, simply bend the two metal parts of the resister and hook them on each side, make sure it's firm ,and try to leave as much space of the hole as possible
insert the new LED bulbs (BETWEEN the resister and the cover), and you're good to go
i'll take some pics if you really want to
Old 07-24-2006, 11:52 PM
andy545's Avatar
Model Year: 2005
Engine: 545i
Yep, pics please...
Old 07-25-2006, 12:52 AM
ICEMAN 316's Avatar
Nice pics neoenvision Glad the resistors worked out for you... after tryin your 200ohm ones lol
Old 07-25-2006, 01:53 PM
madoon's Avatar
My Ride: 2005 525i : Alpine White, Steptronic, Black Interior with Amethyst Leather & Popular Grain Brown, 17" 122-Style Rims, Adaptive Bi-Xenon Headlights, Auto Dimming & Folding Mirrors, Advanced A/C, Sports Steering Wheel, Electrically Adjustable Steering Column, Extended Lighting Package, PDC, Sliding Armrest, Bus Navi, Hi-Fi Sound System (MP3 DVDs), CD Changer, Rear Sunshades.. MODS:M-tech front bumper, Painted Grill, Installed Aux-In, Garage Door Opener (Overhead Compartement), ///M Steering wheel, Wood hand brake trim, Wood gear-shift lever. 35% Tint all around.. Got, ACS Roof Spoiler, but not installed..
neoenvision.. are there any problems with the resistors heating. have you checked them after an hour. how hot are they?.
Old 07-25-2006, 03:02 PM
mlist84's Avatar
It would be great if you can take a picture ... thx a lot!!
Quick Reply: Got my white LED plate lights working without warning triangle!
