FTM (Flat Tire Monitor)
My Ride: 2006 Jet Black/Black 530i
Sport Package
Premium Package
Comfort Package
Steptronic Transmission
Factory Bi-Xenons
Bluetooth
Current Mods:
Black Kidney Grills
Black/White Roundels
Glossy Black Bimmian badge
Smoke Tinted tails
20% Tint (5 percent on rear window)
Okay, the time has come when the only mod left for me to do is a new set of rims (currently using the stock 18" 123's).
So my question becomes is there anything I need to be aware of with regard to the onboard FTM in iDrive when changing to non-OEM rims? My manual says I have a FTM, not TPMS. I don't understand FTM enough to understand the ramifications of switching to non-OEM. Is it a non-issue and just a matter of re-initialization in iDrive?
Can anyone help or point to a good tutorial on this topic. Also, if I move from 18" wheel to 20" is there anything I need to be aware of in terms of the functional driving/handling of the car? Cons of bigger wheel?
Thanks in advance for your help.
All you have to do is reset the pressure in the iDrive, that's what I did. Whenever you change wheels you will get an FTM error, just reset the pressure (there are no sensors on the wheels) and drive away happy.
My Ride: 2004 530i
+1 on what pjinca said. I don't think I've ever resetted the pressure in iDrive when I change wheels. I thought it was all calculations done inside iDrive based on the spin rates of all 4 wheels and compare to see if anyone change significantly (hence, flat tire spins at slower rate).
Sport Package
Premium Package
Comfort Package
Factory Bi-Xenons
Bluetooth
Current Mods:
Black Kidney Grills
Smoke Tinted tails
pjinca & theXman thanks! You guys rock. I notice you both choose to go to 19" rims versus 20". Is there a reason for that?
Also, did you notice any cons in handling/performance of the car by increasing your wheel size?
Handling? Not really - performance? yes, the 20" are larger heavier wheels and have greater rotational mass so stopping is slower and brakes wear a little faster, but with only a one inch difference that's negligible. I chose 19's mainly because I didn't want paper thin tires, a little cushion is better. Some people don't mind but I do (some people also have super hard coilovers, but I would prefer to keep from losing my fillings too)
When you reset FTM in iDrive it calibrates the rotation of each wheel and then knows what a 'normal' rotation is.
My Ride: 2004 530i
