I have read alot of reviews, and most suggest using the Griffin I-Trip for your Ipod. I have just purchased it and seems I have alot more static in this vehicle ( 2005 BMW 530I ).
Does anyone know where the actual antenna is in this car? Does this car have some antenna that doesnt support FM Modulators correctly? I have alot of experience using FM modulators in CD changers and I am well aware of the Frequency response issues and some static issues. ( I work for Alpine Electronics as an Eval Engineer for Audio and Navigation ) However, it seems that this vehicle, in particular, prevents the FM Mod working well. It works, but there seems to be alot of static , unless you are standing at the back bumper . Any suggestions? |
Originally Posted by kflashdot.com' date='Nov 29 2004, 09:30 PM
I have read alot of reviews, and most suggest using the Griffin I-Trip for your Ipod.? I have just purchased it and seems I have alot more static in this vehicle ( 2005 BMW 530I ).
Does anyone know where the actual antenna is in this car?? Does this car have some antenna that doesnt support FM Modulators correctly? I have alot of experience using FM modulators in CD changers and I am well aware of the Frequency response issues and some static issues.? ( I work for Alpine Electronics as an Eval Engineer for Audio and Navigation ) However, it seems that this vehicle, in particular, prevents the FM Mod working well.? It works, but there seems to be alot of static , unless you are standing at the back bumper .? Any suggestions? [snapback]62353[/snapback] the attena i believe is on the back weindshiled ... hense why your i-trip sounds good by the back bumper...but if you want good quality audio from your stock system from your ipod i would sugest getting the AUX input from the dealer |
You can also wire in a modulator into the antenna system. There is actually 3 antennas in the e60 and the system rotates between all three so you need to insert the modulator after the three antennas are combined into one.
Pablo |
Pablo [snapback]62454[/snapback] |
Interesting! I have an iPod and the iTrip. I recently used both on a trip to an e60 meet. I just let it sit on the passengers seat without any problems or static. All worked as they should. I would not expect any differences between the cars. I do have Logic 7 though.
Sorry to hear you troubles. By chance do you have tinted windows? If so is the tint the type that has metallic bits in it's composition? |
remarks:
Fm modulator: means that you modulate the sound to go over the antenna and the radio demodulate again: 2 times lost of quality. white noise is coming up FM transmitter: you send the signal over the radio: works well if you have a very strong transmitter that overules the radio stations (had one, very poor quality sometimes) Aux input: no loose of quality (not hearable) same as your hifi at home |
I had a Belkin and switched to the Moster Cable's FM modulator and it works great in my E60.
