flat tire sensor?>?
My Ride: black 2004 bmw 525i
20x8.5, 20x10 black sevas s-55
i just had my 20" wheels put on my e60 yesterday and today my sensor on my idrive flashed that i had a flat tire and that i need to change my tire, has anyone had the same problem i had? if so, can we bring it up to bmw and have them reset the sensor to where it wont flash that sign??
My Ride: G30 M550i
Model Year: 2018
After you had your wheels changed and the tires inflated to whatever pressure you want to use, did you reinitialize the FTM system in iDrive?
If not, that's what you need to do to teach the car about the new setup. Once the car learns the new setup, it'll warn you if the pressure changes significantly in one of the tires...
My Ride: 550i/ black with aurburn/ sport/ SMG/ m aero kit/ premimum sound/ cold weather/ heated rear/ navigation/20" iforged sprints in gunmetal with PS2's _GONE
I have the same problem on my 07 550i. I installed a set 20" wheels and the TPM malfunction appears. I have tried to reset through iDrive and no avail. Is there any remedy for this?
My Ride: G30 M550i
Model Year: 2018
On the 2007 car, they switched to individual sensors mounted in the wheels (which is why I originally asked what year car disnikhavikta has.)
When you installed your 20" wheels, did you install any sensors?
Can you use the original sensors with aftermarket wheels?
My Ride: G30 M550i
Model Year: 2018
My Ride: 07 530i
Clear Bra
B&B Exhaust
19" ACS Type IV
Pilot Sport A/S
I just spent the money and had the dealer order a new set and unmount/remount my Type IV's with the new sensors. Reset the TPM through iDrive and works like a charm. I just went this way because I wanted to keep my stock setup intact for possible later use.
