Factory Amp Wattage
Old 03-14-2011, 11:42 AM
GsQ
GsQ's Avatar
My Ride: 2007 525i Premium Package "All Black Everything" EXT: 20% Tint All Round | M-Front (Weezy) | Black/White Roundels | Shadowline Paint Match Grilles | M Style Sidemarkers | Vertini Riviera-S 20s INT: I POD Intg | Trim Rings | ACS Pedals | Cobra XRS 10G LHT: Xenon Adaptive | XENESIS Fogs| WeissLicht Plate LEDS | Door LEDS I Interior Xenon Pkg PER: RPI Induction (Weezy) | BMC Filter | Sprint Booster V2 AUD: JL Audio
Does anyone know what the factory amp puts out for wattage to the under the seat factory subs. Also does anyone have some insight to how much power to run to them with a aftermarket amp? Any help on this is much appreciated.
Old 03-14-2011, 11:56 AM
Anzafin's Avatar
My Ride: Bmw 530d 2004
I know Logic7 amp can put 70W per sub.
I wouldn't bother to run the OEM subs with an aftermarket amp. I would add another sub in trunk or replace the underseat subs.
- Antti -
Old 03-14-2011, 12:12 PM
GsQ
GsQ's Avatar
- Antti -
Thank you!!! i have the non logic 7 system do you think it is the same wattage?
Old 03-14-2011, 12:16 PM
Anzafin's Avatar
I really don't know. I just checked the Wiring Diagram System and it doesn't tell the hifi amplifier specs, only pro hifi amplifier (Logic7). I could guess it's the same power with a hifi amplfier .
Here's a copy-paste:
Audio amplifier
The sound reproduction is optimised by the 2 types of amplifier:
* Stereo/HiFi amplifier and
* Top HiFi amplifier.
They are fitted according to the desired type and number of speakers:
The active frequency gates transmit to the amplifier module concerned only that frequency range that can be effectively reproduced by the connected speaker system. The speakers (high, mid and low-range speakers) are connected to those output stages.
Brief description of components
HiFi amplifiers are amplifiers with active frequency gates. Active frequency gates achieve better acoustic results than passive frequency gates.
The HiFi amplifier does not have speed-dependent volume adjustment or speed-dependent equalising. The function of the HiFi amplifier is only to amplify the low-frequency output. The HiFi amplifier is a non-diagnosable control unit.
Top HiFi Amplifier
Top HiFi amplifiers are amplifiers with active frequency gates. Active frequency gates achieve better acoustic results than passive frequency gates.
The Top HiFi amplifier is a control unit on the MOST network which has following functions:
* High and mid-range output stages, 4 x 40 Watt
* Subwoofer output stages, 2 x 70 Watt (2-channel subwoofer amplifier)
* Vehicle-specific equalizing
* Speed-dependent equalizing
* Volume-dependent equalizing
Old 03-14-2011, 12:20 PM
GsQ
GsQ's Avatar
I would guess that it is most likely the same. Thanks for the info thats a handy system diagram you got there!
Old 03-14-2011, 12:22 PM
Anzafin's Avatar
BMW Wiring Diagram System
I think the diagram doesn't fully work on my computer due to some software things, but it helps a lot when looking for text info!
- Antti -
Old 03-14-2011, 01:11 PM
response_surface's Avatar
My Ride: 2005 545i Sport 6 speed Manual
don't know the factory amp output, but it ain't much.
check this out, its what i did to deal with the issue. i used earthquake subs and an arc audio mini in the factory location without cutting any factory wires.
check out the amp guts pic, and how it compares to the arc mini.
i laughed out loud when i took it apart!
https://5series.net/forums/topic/110...m-sub-upgrade/
Attached Thumbnails Factory Amp Wattage-factroy-amp.jpg   Factory Amp Wattage-amp_compare.jpg
Old 03-14-2011, 03:31 PM
GsQ
GsQ's Avatar
whoa there is nothing in the factory amp lmao! unless it is splitting atoms it doesnt loot like it put outs much
Old 03-14-2011, 08:42 PM
musicalmike's Avatar
http://forums.5serie...em-sub-upgrade/
How did you do it without cutting any wires? Can you show any pictures to help?
Old 03-14-2011, 11:01 PM
GsQ
GsQ's Avatar
you wouldn't need to cut any wires the amp simply unplugs from the connective harness and then is held in place in the left boot bracket on a rail by some philips screws i think which would allow you to remove it completely.
Quick Reply: Factory Amp Wattage
