Exterior LED Upgrades (Front, Rear, Side Turn Signals, Brake, & Reverse Light Bulbs)
Hey,
I want to upgrade all my exterior lights pre-LCI to LEDs since some of my lights are out, could you guys give me some guidance in which kind and style LED bulbs would be best and affordable for each type of light like projector, non-projector, SMD, etc. for these upgrades that I can get from eBay or a better source. I plan to get the car coded so there's no need to run resistors or spend the extra money for error free LED bulbs.
DRL/High Beam H7 Bulbs: I was thinking white something like these?
http://www.ebay.com/itm/360534335645...84.m1439.l2649
or
http://www.ebay.com/itm/360554263192...84.m1438.l2649
Front turn signals: I believe they're 3156 bulbs, or are 3457 a better choice? I want amber color and really don't know which kind to go with these:
Benz 2X Amber LED Daytime Running Light Bulbs 18 SMD 3156 3157 3757 4114 4157 | eBay
or
2 3157 3457 3057 White Amber 60 SMD LED Car Front Rear Turn Light Bulb Lamp | eBay
Side Marker Bulbs: I believe these are T10 bulbs and i was thinking about amber Projector style since they're kind of exposed like:
T10 194 W5W Amber Auto Interior Dome Wedge Light Bulb Bulbs 5SMD High Power LED | eBay
or
2 Pcs Amber Yellow T10 High Power Lens License Plate LED Light Bulbs 194 168 | eBay
Rear turn signals: I'm not quite sure which bulbs are the right one for the rear turn signals but I amber as well, can someone recommend the right bulb and style
Brake bulbs (inner circle): I want to get these spider 5 arm style b/c I think they will stand out and look nice in the housing but I don't know which one back side one is needed:
New Spider 5 Arm 40 SMD LED Amber Brake Stop Tail Light Bulb Green | eBay
or
2pc 3157 5 Spoke Arm Spider Lite Red 40 SMD LED Tail Brake Signal Light Bulb 12V | eBay
then there's 2 brake/rear fog bulbs for outer brake lights that I want to change out too but i'm not quite sure what bulb size they are but for these I was just thinking some standard style SMD LEDs or something like these so you could see the shape of the LED bulbs so it can stand out a little more with the 5 arm Spider LED inner brake lights.
Last but not least the reverse bulb, not sure which bulb this is either but I was thinking projector style for these so their nice and bring at night since my rear window is tinted and can be hard to see sometimes when reversing.
Thanks in advance for the help!
or
or
or
or
i wanted to do the drl and the brake too, let us know with some pic if you actually tried it out.
i would personaly go with
2x7 5W High Power H7 SMD 5 LED Headlight Bulbs Fog Driving Light DRL White | eBay
as for the brake like we can just take out our current blub to take a quick look.
what i most worry is they might triger some error for the car thinking the light bulb are out? i am having trouble with 1 of my license plate led now.
they probably will cause iDrive errors but I plan to fully upgrading all my bulbs then coding them out
socale39
09-05-2023 08:30 AM
