E6x Rear Camber Kit Comparison
Old Jun 4, 2010 | 07:20 PM
schulrog's Avatar
http://www.k-mac.com/
vs.
http://www.spcalignment.com/PROD_DIR...d2=72185&cmd3=
I decided to get a camber kit to get rid of premature inner tire wear.
The first kit i got was the K-MAC camber kit for the rear and that didn't quite work out. The kit never tightened fully causing a squeaking noise and moved around grinding into the metal on the lower control arm and eventually the bolt broke since it was a lower strength steel.
Then I found the SPC camber kit and it has been awesome. All materials are made of extra strength steel and a the kit is mounted on the upper control arm instead of the lower load bearing control arms.
Nihilation
Jul 10, 2022 11:32 AM
dsummersm3
Nov 14, 2019 07:50 AM
benrinnes
F10 Discussion
May 8, 2015 08:52 PM
carid
Mar 27, 2015 04:47 AM
Eborlindum
Mar 23, 2015 02:15 AM
