E61 LCI retrofitting a westafallia tow hitch
Old May 13, 2025 | 01:51 PM
marcello21's Avatar
Probation Members
Default E61 LCI retrofitting a westafallia tow hitch
Hi all,
Just did a installation and wiring done for tow hitch as per installation instructions and right now only brake lights are on (without pressing the brake pedal).
I did triple check and am sure that wiring is done correctly. My only version about what could be wrong is that I need to install / code the new Trailer lights module. Installation manual states:
-Change in the ISTA/P car programming
-Select the “Trailer tow hitch” retrofit via the – Conversion – path and work through the created action plan
In some threads here I have read that it is best not to use ISTA/P, but instead use something like NCS expert.
Could this work be done through NCS expert or should I use ISTA/P? Do yall think the convertion would solve my problem?
This-Rex
May 16, 2024 09:35 PM
Gad1nski
Nov 14, 2021 10:08 PM
yiqiuc
Mar 14, 2017 02:23 AM
Mikethepanel
Jul 13, 2012 11:26 AM
bruce_miranda
Sep 1, 2008 11:23 AM
