E61 Lci heated seats into pre-lci
Hi all,
I have a 2005 e61 which came with basic semi electric leather seats, none heated. I have fitted some heated Msport seats from an Lci E61.
Is it possible make the heated elements work with a pre-lci car and pre-lci heated seat buttons?
Thanks
Olly
Thanks
Olly
If you've got everything wired but it isn't working then I would check fuses and then start digging on coding differences. If a HUD can be retrofitted then this should be reasonable with the right people. Do you have a decent local shop to reach out to?
I haven’t wired it yet as I wanted to see if it’s been done before as my understanding is that the pre lci get a can signal directly from the buttons where as the lci seats get a single wire signal from the body module so unsure if I should wire it like an lci and code the body module like that or if I would need pre lci seat modules.
I did the same thing on my E60 I went from Heated sports seats to heated Comfort seats and everything works but the seat heating. I think I will have to be happy with that how about you did you get the seat heating to work?
V/R
Victor
V/R
Victor
OldManSedan (03-05-2020)
