E61 - Climate Control Coding
Hello,
hopefully somebody can help me to get my climate controller coded as it was before :-)
There are no modifications it's a originally fitted E61 pre face lift, high controller.
A few days ago, I had to flash my CCC, everything went OK accept the climatic control settings are not working as they should (or as they worked before).
Formerly I was able to change the vent from upper/middle/lower individually for the driver and passanger.
But nowI can not pick the vents (3 vents für driver + 2 vents for passenger)in the climate-menu. I can only pick the setting (between driver and passenger) to increase/decrease some lines from red to blue. Thats all. For e.g. now its not possible for me to give full boost to the feet.
Does anybody know which moduls are related to the climate controller - and which settings have to be done?
The only thing I found was in CAPPL: KLIMA_SG_ART_CCC -->high but thats not the right thing.
Thanks in advance
Matthias
Thanks in advance
Matthias
i understand this is like a decade old post, but i am having the very same issue.
However, i tried coding va-noairvent_finetunning and every time i change it to aktiv and then code it and execute job, it reverts back automatically to nich-aktiv. It's like it doesn't want to replace it to aktiv ?
Any help ?
Any help ?
Hello,
I really would like to help you, but to be honest, I‘m not anymore in detail.
I don‘t even have the the software on the computer.
In 2011 I tried to document what I did with my second post, that’s all I know.
Could it be, that you have not properly saved the TXT file, so it always returns to the old setting?
I hardly remember a „Flag“ to be set, so you are able to safe any changes.
Best regards
Kerni
Best regards
Kerni
Engine: 3.0 B58; 3.0 M54
You're not properly coding it. You're changing the setting but not saving or applying it correctly. When you code it will change what you set no matter if it's correct or not.
of course, i am more then 5 years with BMW e60, so i am aware how to use idrive knob
I click and nothing happens, but here is another video that demonstrates how i can actually change vent direction with temperature knobs, its like everything is swapped around or something.
I click and nothing happens, but here is another video that demonstrates how i can actually change vent direction with temperature knobs, its like everything is swapped around or something. Super Moderator
I wasn't trying to insult your intelligence I just couldn't tell what you were doing in the video and I don't put nothing past anyone since I'm not there looking at it myself.
I don't think it's the knob or it wouldn't work at all. I think there's a coding issue
