E60 wheel fitment question....again
I have yet another fitment question. I'm relatively new to the E60 board and just got my 550i a few weeks ago. I am looking at the crosspoke type 101 wheels and wanted input on fitment with the 20inch rims available from BMW. The fronts are 20x9 ET 24 and rears 20x10 ET 24. Do you guys know if these will work or if there will be a rubbing issue and also which tire sizes are reccomended. The dealer suggested I stick with the 19inchers. The offset is ET 20 for the fronts and ET32 for the rears on those. Thx in advance Kal
My Ride: Bmw 530d 2004
See this page: http://crass.on.ru/bmw/wheels/style/style_101.htm
When comparing these two sets (20" set for E65/66 vs. 19" set for E60), the next calculations can me made:
The difference in front wheels:
- 9x20 ET24 would sit 9mm outer in a wheel arch than 8x19 ET20 --> So MAYBE with a right tire size it could work. I doubt.
The difference in rear wheels:
- 10x20 ET24 will sit as far out in a wheel arch than a 9,5x19 ET32 --> No problems, but again, the right tire size is needed
I hope this helps.
- Antti -
Fronts may rub the struts - gotta see how much space you have there. OR, if you put a spacer, they might run the wheel arch.
Rears, I think will be more or less ok, as long as you know that you may need spacers.
My Ride: SOLD...Jet Black 2008 550i M Sport with SAT, black interior. RPI exhaust and air scoop, 35% huper optik tint all around, CF roundels, flat black kidneys, Springfield Armory XD-40 jet black in glove box, charcoal filter removed.
Guys I see alot of members with 20" wheels and lowered suspensions on here. How do they do it then? I've been trying to get a good list of the parts needed to do this to no avail. I personally love the look of the lowered suspension with 20s.
thanks.
thanks.
thanks.
thanks.
Use this site - it will give you some idea.
http://www.1010tires.com/WheelOffsetCalculator.asp
AFAIK there should be no problems running 20s, as long as you do it with correct offsets. You may want to ask people who have these setups what suspension they are using, what size wheels and tires they are running, offsets and whether they have spacers or not.
thanks for the info Vlad!
My Ride: 2007 530d M Sport Automatic, Le Mans Edition.Le Mans Blue Individual Paint Special, Syrah Blue Individual Leather, Piano Black Individual Interior Trim, Front seat heating,M Double Spoke 172 19
Originally Posted by Anzafin' post='1058235' date='Nov 19 2009, 11:48 AM
Exactly. To be precise the 20" would sit 17mm more in.
Originally Posted by tooltec' post='1058260' date='Nov 19 2009, 03:35 PM
For the rears ,a 10" wide rim with a 24mm offset will protrude 14mm further out from the hub mounting face compared with a 9.5" wide rim with a 32mm offset.The inboard position would be within 1mm of the 9.5" rim.
My Ride: 2005 BMW 545i
To the OP, sounds like a good setup. I think if you get 20'' wheels and put 245/30/20 F and 285/25/20 R or 245/35/20 F and 275/30/20 R you should be fine. You might rub a tad on bumps, but that's nothing a fender roll can't fix.
bestofthebest
03-30-2015 08:12 PM
