E60 Plugs and Connectors
In this photo here:
![](http://static.bmwfans.info/images/epc/MTI5MTQ0X3A=.png)
Does anyone know which of those parts match (male and female connections)?
Need to join 2 cables from the car to the 2 cables of the power from a Dension, but don't want to solder and need a plug type connection.
Part 1 would be the best since its got 2 pins but no 2 pin male socket.
Next would be 2 and 3 which are both 3 pins, and I suppose I could leave one pin blank. But I'm not sure if they fit into one another.
My Ride: 02/2006 525i Titanium Silver Metallic
Manual 6-Speed
I would use #2, and leave the middle pin blank.
You can use parts #2 and #3(maybe #5 can't tell from pic) for your connection, and also you would need 4ea of part#61130005197 bushing contacts (black wire with square end) that will plug in to your connector plugs.
Stormcrow
12-01-2019 02:09 AM
