E60 M5 Stock Exhaust
Old 01-07-2006, 12:24 PM
wolverine's Avatar
Not sure if I can post this audio file. If I can, I'll post another when I get my resonator removed.
Old 01-07-2006, 12:58 PM
wolverine's Avatar
http://www.savefile.com/files.php?fid=3775994
Let me know if this works.
Old 01-07-2006, 01:27 PM
E1142860's Avatar
It works. What was your final speed?
Old 01-07-2006, 03:24 PM
Banned
stream's Avatar
[/quote]
Nice. That's the most realistic sounding sound clip of an M5 exhaust I've heard, compared to what I've heard in person.
Old 01-07-2006, 05:16 PM
wolverine's Avatar
[/quote]
Great. I started at idle, then ran the car up to 7,000 rpm, pausing at each 1,000 rpm increment. Then I did a few throttle blips, then back to idle. I'll repeat the process when I have the resonator removed.
Old 01-08-2006, 08:24 PM
jet190rs's Avatar
Nice, wished my 545 sounded like that!
Was this recorded from outside or inside the cabin?
Old 01-09-2006, 04:30 PM
wolverine's Avatar
This was recorded using my laptop, this was outside, laptop on the driveway about 5 feet behind the rear bumper of the car. I'll use the same setup tomorrow to record the sound without the resonator.
Old 01-10-2006, 01:25 PM
wolverine's Avatar
Here is the soundfile with the resonator removed. We just substituted two straight pipes for the stock resonator, which is two separate 'glasspack' type chambers in one outer housing. The sound is terrific - I would highly recommend it if you're looking for just a bit more exhaust 'spirit'. I will probably go a little bit more, and install aftermarket mufflers as well. Let me know what you think.
http://www.savefile.com/files.php?fid=7601412
Old 01-10-2006, 02:10 PM
jet190rs's Avatar
Sounds good wolverine. It seems only slightly louder and deeper, I was expecting a much more drastic change.
Old 01-10-2006, 02:48 PM
wolverine's Avatar
[/quote]
I was too - it is definitely much less than I thought it would be. But I really like it - driving around with the window open, it really sounds much better than before - but it's not a big change. This change has convinced me to go to an aftermarket exhaust, probably Eisenmann or Supersprint. If I think it's too loud, I can replace the resonator to tune it down a bit.
Quick Reply: E60 M5 Stock Exhaust
