E60 M5 BBK on a 530i
Old Sep 14, 2008 | 03:31 PM
  #21
BB-Tjai's Avatar
Originally Posted by seoulman' post='669284' date='Sep 15 2008, 12:11 AM
A 4 piston Brembo BBK for the front should cost a bit less than the M5 BBK. I've seen prices between US$2700 and US$3000 for the kit.
Where have seen those prices?
I haven't got any luck yet founding them.
Most companies only offer the 6 pistons front.
Old Sep 14, 2008 | 11:18 PM
  #22
seoulman's Avatar
My Ride: 2014 530d XDrive M Sport
The Brembo BBK I am referring to is the Grand Turismo F50 kit with a 4 piston caliper. The 6 piston version has a mono-block caliper that costs much more. Did you contact 'r1racer' (Joe) or 'nerweezy' (Nerwyll) at Trinity Autosport? They should be able to help you out. Joe and Nerwyll are members of this forum. Drop either a PM.
Old Sep 15, 2008 | 12:54 AM
  #23
BB-Tjai's Avatar
They only offer the 6 pistons front.
Old Sep 15, 2008 | 03:52 AM
  #24
JPJ's Avatar
JPJ
Stop Tech doesn't show a 4 piston front kit on their website, but at the SEMA show last year I talked to the head of engineering for a while (guy I was with knew him). He said they could hook me up with a 4 piston front kit that would cost less and give plenty of performance. Drop them a note a ask what they could do.
Old Sep 15, 2008 | 04:18 AM
  #25
seoulman's Avatar
The following cars belong to members on the forum and have the Brembo Grand Turismo 4 piston front brake kit that I am referring to. If you get 380mm rotors, the cost is very expensive and it comes with 6 piston calipers. The model I am referring to has a 345mm rotor and has 4 piston calipers. I found the model numbers on the TireRack website. If you shop around, you will be able to get better pricing than from TireRack.
http://www.tirerack.com/brakes/results.jsp...ry=BigBrakeKits
Attached Thumbnails E60 M5 BBK on a 530i-index123.jpeg   E60 M5 BBK on a 530i-modified_bmw_5_series_e60_brembo_gran_turismo_brake.jpg   E60 M5 BBK on a 530i-index363.jpeg
Old Sep 15, 2008 | 04:33 AM
  #26
BB-Tjai's Avatar
I will do a good search on the net for companies that offer them. But there are not much companies offering these.
But if you find some please post it here.
Thank you.
Old Sep 15, 2008 | 04:37 AM
  #27
seoulman's Avatar
Thank you.
If I find any companies offering the 4 piston Brembo Grand Turismo BBK, I will definitely let you know. However, the TireRack site lists the manufacturer part number, so it should make finding the BBK a bit easier. When you are ready to do the rear set, the rear brake caliper will look like this.
Old Sep 15, 2008 | 04:46 AM
  #28
BB-Tjai's Avatar
Tirerack only shows the 4 pistons rear, can't find the 4 pistons front. Only the 6 and 8 pistons......
Old Sep 15, 2008 | 04:58 AM
  #29
seoulman's Avatar
Sorry.... my bad. I didn't read all of the info on the TireRack site. I know that there is a 4 piston Brembo BBK out there for the 5 series. The pictures I posted back that up. Just let me find the manufacturer's part number for you. If I can't find the part number on the web, I'll ask a trusted local tuner. I know that he has done many Brembo BBK upgrades on BMW 5 Series.
Old Sep 16, 2008 | 11:43 AM
  #30
seoulman's Avatar
I've asked my local tuner to get me the part number for the Brembo Grand Turismo F50 4 piston front brake kit that fits on an E60. In the meanwhile, check out this deal. It's not Brembo, but I heard JBT makes awesome brake systems like StopTech (which may be another option for you). Eurorev was offering JBT 8 piston front and JBT 4 piston rear together for US$4900! That is a deal! Check out the links below.
http://forums.e60.net/index.php?showtopic=...mp;#entry653431
http://www.jbtmotorsports.com/index.htm
