e60 eLight module any1 tried it yet?
I also asked about this module in another thread about fade-in AEs, but noone answered either.
However, the Germans are buying and using this like crazy, so I am pretty sure it works just fine. The only problems I've read so far are that the cable between your PC and the module sometimes does not work, because it requires a special sort of port on the PC.
To me, it's a matter of time, money to throw away, and availability of alternatives (cheaper coding etc.) before I get this. I also want my car to wake up like a beast..
i have no clue about that
re: the cable, the germans are actually having problems with the cable that links the eLight module with their PC. this cable is supplied by the eLight vendor and is needed to do load all the settings on the module, which prior to that you have defined on the PC with the program in the package
Sorry to wake up this old thread .I got one of these module and can not get it to work ( pre 2005 car )
Has any one made progress with this
from what i understand u can not get welcome lights on a pre lci car - please correct me if i am wrong
unless u buy a new light module
thanks
thanks
the software can be downloaded here http://www.car-solution.de/en/downloads.html and you just need a serial cable which goes from the module to the pc for programing
The software has the install instructions as well
(Sublime )
yep they do
here also they sell it
http://www.mstyle.co.uk/acatalog/BMW...bulb_kits.html
I have pm Rizbel and hope he can help -
yep they do
(Sublime )
yep they do
http://www.mstyle.co..._bulb_kits.html
yep they do
