E60 CIC Retrofit, USB, Combox - 2006 BMW 530i
Old Jan 12, 2025 | 11:15 AM
  #261
gmcclintock's Avatar
My Ride: 09 F02 & 07 e60
Originally Posted by smartshah
@gmcclintock@hotmail.com
Which modules are you trying to write your VIN to?
You have to be very specific as there are many possibilities here
The following are the module names that display yyyyyyy, 00000000, or incorrect VIN in INPA I've dome made many changes to the car but can't figure this out so I've just been living with it.
CDC, ZBE, FAS, BFS, LM, CID, KLIMA, VIRTSG92, CCC (No longer in the car) MOSTGW, MMI/CCC
Old Jan 12, 2025 | 11:30 AM
  #262
smartshah's Avatar
My Ride: 535d M Sport
I have seen certain Modules in my car, which does not show the VIN. You can do this via Tool32. I have and many other members have given details on this, in the previous posts. Please go through them.
Old Jan 12, 2025 | 02:11 PM
  #263
Ok I'll take a look
Old Jan 13, 2025 | 09:20 AM
  #264
Dj530's Avatar
My Ride: 2006 530xi (One black & one grey) 2010 X5 35d 1974 BMW 3.0CS 2008 535i, 2009 335d, 2011 X5 35d, 2008 335i FBO
Ok I'll take a look
I also use BMW E/F scanner to change VIN info on ECU and tcu for test tuning and it's always worked great for me, no "coding", just change vin option and enter new 17 digits. . . . I kind of use that as my gotto now . . . . I will have a look later and see if it also does all the other modules as well.
Old Jan 13, 2025 | 09:42 AM
  #265
kirvedx's Avatar
My Ride: 2006 BMW 530XI, CIC/Combox/TPMS Retrofit (CCC M-ASK Orig)
Engine: N52
The best way to handle this is to use Tool32. There are usually up to 3 ways to handle updating the VIN for a module; c_fg_schreiben, c_fg_auftrag, and aif_schreiben. The latter will ensure that the VIN is properly displayed in INPA and elsewhere; Though you aren't always able to use it - so it's not going to be 100% guarantee that all modules will show the VIN properly. The issue is with the latter requiring parameters that aren't always available - and no matter what you put for them it tends to simply fail.
You should be able to fix it for most of the modules though.
Old Feb 4, 2025 | 03:48 PM
  #266
Originally Posted by TeflonDon
I'm in Gwinnett County... If you need help.... I'm local until March 31st...
I have put most of the files together that anyone with a E Series will need to complete a CIC Retrofit.... These files should also help those with NBT EVO Also.....
Folder is just a little over 11GB ...
This is because of the SP-Daten v67.0.000 - Over 8GB - Which includes - E60 - E65 - E70 - E89
How do I get access to this information? need to complete my retrofit.
Old Feb 4, 2025 | 04:02 PM
  #267
seanjordan20's Avatar
Engine: 3.0 B58; 3.0 M54
Google it. It's online for download everywhere
Old Feb 4, 2025 | 04:04 PM
  #268
kirvedx's Avatar
Engine: N52
You can search the internet for standard bmw coding tools, you should find something at bmwcoding. From there, for the pirated stuff (SP Daten), you'll likely want to go the torrent route (though you may find some of those cloud storage posts are still around, could always DM the owners of the posts and ask.)
Nobody is going to otherwise post a link to pirated software as It's typically against the EULA of any forum/community. Others will say if you had to ask how to get access to the information, you may (I'm stressing the may), want to hire someone to do it for you. You can always follow the guides on the hardware and let someone code for you remotely. Start a thread in the right place about it and you'll likely get the reply you want. If you go that route, save that question for them. If you want to do it yourself, you should head to bmwcoding and read their newcomer thread, and then proceed from there.
Old Feb 10, 2025 | 10:17 AM
  #269
Thanks I'll do as you recommend, and for the record I have no problems hiring someone however everyone I message do not respond so my only option is to try and figure it out myself or asking folks on the forums which only ends up in incomplete information.
I appreciate your response and recommendation though.
Old Apr 16, 2025 | 02:22 AM
  #270
entrippy's Avatar
My Ride: E60 M5, Alpine White
I DM'd @TeflonDon a few days ago for the password but haven't heard back. Can anyone DM it to me?
