E60 CIC Retrofit, USB, Combox - 2006 BMW 530i
Old 03-08-2023, 04:41 AM
  #221
smartshah's Avatar
My Ride: 535d M Sport
Here
Old 03-08-2023, 07:50 AM
  #222
Bmwpower530's Avatar
My Ride: Bmw 530xd E61
I think its not disabled, its like conditions no met. Try simple thing , reset CIC by holding volume button pressed.
Old 03-08-2023, 07:52 AM
  #223
smartshah's Avatar
I reset the coding on it recently that should restart the CIC. I will have a look at the KOMBI coding and see if it is hidden in there. But if it was hidden it wouldn't show that screen at all
Old 03-08-2023, 07:57 AM
  #224
first photo with ignitiion on, second after start, 3 after 10-15sec.
Old 03-08-2023, 07:59 AM
  #225
smartshah's Avatar
Yes mine only shows that pic I sent you al the way through
  #226
You never had it working after retrofit?
Old 03-08-2023, 08:01 AM
  #227
smartshah's Avatar
before retrofit I had the CCC, I don't think the CCC shows oil level.
​​​​​since retrofit it hasn't changed the message
Old 03-08-2023, 08:17 AM
  #228
So you have to dig more, maybe start from Kombi psw_fsw file, seems that kombi sends info about vehicle to CIC.
Old 03-08-2023, 08:40 AM
  #229
smartshah's Avatar
Seems like there are 2 types of oil sensors on the oil
One which senses low oil level
One which shows the oil levels.
​​​​​​Is that true?
https://5series.net/forums/e60-discu...-148062/page2/
Old 03-08-2023, 09:30 AM
  #230
That one that solved by updating ecus?
"Connect 14v 100a power supply to booster connections under the bonnet. Connect the MOST lead to the MOST ring socket behind the glovebox top lid, connect to the ICOM interface, run ISTA/P and reprogram, recode and reinitialise the DME, DSC, EGS, SZL and KOMBI!"
You can flash and code these using k+dcan cable, first read your uif and check with winkfp is there a updates.
Quick Reply: E60 CIC Retrofit, USB, Combox - 2006 BMW 530i
