E60 AUX Questions
i have an 2005 530i i was looking into installing aux retrofit part no. 65 12 0 153 502 but i was told that the aux will not sound good i will need to get an iPod adopter i wanted to know if this is true or not since i do not really know much about it
My Ride: 545 modded the F out
I have both. Only reason why I ever use the Aux is when Im watching DVD's through my Idrive screen. They obviously service different purposes, but both will still need t be coded in order for them to work. With the iPod integration you'll at least have the capability to maneuver through your music via the drive. The aux does now allow you to do this. Sound quality, to me at least , is the same.
i am in the middle of installing this myself - i bought the coding cables and wwas sharp enough to get them installed but I am waiting for warm weather to pull the dash apart. I read that this is the same part as the older e3X but the pins are shaped differently. I also read its beneficial to remove the resistor from that BMW part to increase sound volume. esstitaly it makes the cable a standard aux cable . i made a cable with a standard 3.5mm cable, cutting one end off and affixing female pins (radio shack, super cheap) on the L R and ground. Ill let you know fidelity i think ill be doing it this afternoon
install went pretty well i finally took the plunge and did some coding and it went great!
the aux fidelity is pretty good, its better than fm radio for sure haha but not quite as good as cd. I will be spending a LOT of time using the aux and i dont think the sound quality is going to upset me whatsoever. (note, i did build a cable but will end up attaching a resistor as im getting a "whine" through the aux input that matches alternator speed)
My Ride: 2008 AW N52 with sports package & premium package; natural brown interior
MODs:
Orion V2s
3000K H8 Yellow Fogs
Matte Black Kidney Grills
20" Miro 111
Hankook V12 Tires
H&R Sport Springs
Special coding via Simon (dbl flash hazards, digital velocity, etc.)
LED Side Markers from Trinity Autosports
LED License Plate Lights from Trinity Autosports
Carbon Delete
BMC Air Filter
RPI Scoop
RPI GT Exhaust
Future MODs:
Mtech Kit
KW Variant 2 Coilovers
CIC Retrofit
Upgrade Audio System
