Hey all. Looking at a e0 intercooler on amazon. Appears to be a bolt on for the e60. Tuning Performance Intercooler Fits For BMW 635d E63/E64 525d 530d 535d E60/E61 04-10 https://www.amazon.com/dp/B07SNSVHL4/ref=cm_sw_r_cp_api_i_VzViDbXPTQE47
anyone used this? I would need to use an aftermarket trans cooler. However that is pretty doable. And for an intercooler that I don’t have to Jerry rig I would be willing to make it work.
I literally just got my Wagner performance IC today. That looks exactly like it, wait it is a Wagner. You can clearly see the round Wagner logo on the top picture.
Wagner Tuning Performance, damn. But hell they have them on ebay from China with labeled as tuning performance.
I wonder what gives because I paid 300 more.
I hope I bought quality with those 3 bills
What makes you say aftermarket trans cooler is needed?
I haven't turned a screw yet and don't know how it will fit, let alone what will happen to the trans cooler.
I searched high and low and couldn't find any E60 XI or i Wagner installs.
The Wagner states module support will need to be modified for the TOC
I was going for the PSP but they were out of stock and they responsed to my email with a no ETA for when they would have them.
The Wagner states module support will need to be modified for the OTC
almost everything is made in China man. Just varying levels of quality control is what I have found you pay for with car parts. I think that this IC has been around for awhile in Europe as they didn’t make the 535i there to my knowledge. Tuned 535d’s are running around 28psi so I would imagine these will be more than sufficient for all but the most extreme power goals.
There is a trans cooler is mounted in front of the intercooler on the e60. It will need to be mounted creatively from what I can tell. Not sure it the trans cooler old mount will work. I have been trying to figure out the best location. Space is tight up front on mine as I have night vision and stop start cruise.
I will have to buy it and figure it out.
I am in phoenix And would be happy to help with install if you are nearby so I can have a look.
Mine is made in Germany.
Good read.........https://www.e90post.com/forums/showthread.php?t=1246272
And I know about the TOC location. I am using the stock bumper.
Ill post pics when I start.
I will probably just take the bumper off
Well folks,it butts right up to the power steering cooler. Bummer.
The Wagner went in smooth as silk otherwise.
Maybe not ideal but I am going to hang it from the bottom of the bumper with L brackets and the factory clips.
I have to grab some screws from work tomorrow. The brackets are cut and drilled already.
It should be a solid solution maybe not the most solid for fluid cool air flow.
Either way it will be heads above the factory set-up.
So here is what I ended up with.
Angle brackets cut to fit, #12, 3/4" self tappers with factory mounting clips.
I'm impressed with the ease it slipped in but not pleased where I had to mount the TOC.
It blocks the upper step, hopefully not in a mind numbing WTF way.
It will be interesting to log and to be honest not really expecting any miracles.
I should have hung on until the PSP 600 was back in stock.
Did you have to do any cutting or trimming of any plastics
