Which do I use...
Planning to change the front turn signals... I believe in the UK they use PY21W bulb for the front and US spec vehicles use another kind...but for me, the car is a Canadian spec...so I wasn't too sure which to follow...I checked my manual and it stated PY21W for front and rear signals....now my question is are these the right type to order?
http://cgi.ebay.com/ebaymotors/PY21W-silve...tem300211568261
another member recommended the 7507 bulb
http://cgi.ebay.com/ebaymotors/7507-silver...sspagenameZWDVW
Which bulb type do I order?
Originally Posted by alpinewhite' post='552799' date='Mar 29 2008, 02:29 PM
the ones you should get is imprinted on the stock amber bulbs (check them)!!
I made the mistake in ordering the 7507. Check the oem bulbs!@!!!
Your owners manual or bulb selection charts are not always correct. It is an extra step but better to take it before you buy the incorrect bulb and have to return it.
The front turn signal bulb is very easy to remove and inspect so you can replace it with one that is compatible with the exact original part number.
daddymalu
Oct 17, 2011 08:55 AM
bmw_wpq31
123
Sep 5, 2011 01:19 PM
monsterj34
Detailing Forum
Aug 1, 2010 12:18 PM
