Do I need to buy the tire sensor monitors
My Ride: 2004 545i SMG
Im about to buy the oem 166's from bmw of newport and was wondering if i really need the tire sensor monitors or not?
thanks in advance guys,
jeff
jeff
Originally Posted by delje08' post='548208' date='Mar 20 2008, 01:46 PM
since you have a 2004 you dont need them since they are not built in.
and where are they instead?
I have a 2004 car. Our cars calculate diameter of each tire. No need for sensors. Once the rubber valves & wheels are installed, set via iDrive the tire monitoring. Be patient because it takes some miles to drive in order to measure the diameter of each wheel. If you get a flat, diameter changes and you get notified that one tire is damaged. We cannot say which one, but with non-RFT - you will see which one.
