Differential from automatic to manual gearbox
Hello. I am interested in whether there is a difference in the differentials of an automatic and a manual gearbox. I want to change the differential of my 525d 197 hp. with gear ratio 2.56 with one from 530d e60 automatic with gear ratio 2.47.
Is there a difference in the drive shaft, drive axles, clutch and so on?
In the photo they look the same with the difference that the 530d e60 2006y has a cooler.
Thank you in advance.
[img]data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAABQAAAAUCAQAAAA ngNWGAAAA/0lEQVR4AYXNMSiEcRyA4cfmGHQbCZIipkuxnJgMStlMNmeyD2d wmc8+sZgxYJd9ErIZFHUyYYD7fkr6l4/rnvmtl7+KitrqV/fq2Y5eLY3Z9S48eRLe7BmVZ9qhTLhQ0algzZWQOVKSsCF8OjAn wbxDTWFDUhPK/jMr1H6HE/IqRky2DyvCefuwItwZzodVoYRiLqMkVCXrwpJ9twZ+sgfDYEFY l8wIWxZ9uFf7zkallxlJh4YrLGsKjZRx7VGHhLqwgFUN45DGdb 8MeXGpgB4ABZdeDcpZEY51A+hyLKz4S1W4MQWm3AibWtgWmk6d yISa1pSdyWTOlLXVp0+eL9D/ZPfBTNanAAAAAElFTkSuQmCC[/img]
My Ride: 2005 525i (manual swapped)
manual and auto 525d and 530d use the same axles and diff case. The only difference between the manual and auto is the manual drive shaft is 15mm longer.
