Difference between the sound systems offered
Old 02-19-2009, 08:36 AM
bruce_miranda's Avatar
Originally Posted by Dr Dave' post='796792' date='Feb 19 2009, 05:29 PM
this car has not been tinkered with bruce?
i also have those speakers near the mirrors?
so do i have logic 7? i didnt think i had
here are pics of the 2 door speakers im on about
2 speakers near the mirrors are there in the hi-fi too. But rear door speakers are only in the L7 and above. Someone (you) may have just put trim panels in the rear doors with the speaker grills on, without speakers behind them or wired the rear speakers up in parallel with the front speakers.
The best thing to do is open your Left wheel arc trim and look for the size of the amp. If its huge like my picture you have L7 but if you see a small one then its Hi-Fi, if you can't find one you have the Std EU version.
Old 02-19-2009, 08:39 AM
Dr Dave's Avatar
the amp looks small (ish) ??? on the 535d
my 530d does not have an amp there.
and the car in question is not modified...its standard.
Old 02-19-2009, 08:56 AM
Picture of the Hi-Fi amp http://forums.e60.net/index.php?showtopic=...st&p=647490
Picture of L7 amp http://forums.e60.net/index.php?act=attach...st&id=61849
Old 02-19-2009, 09:18 AM
mikeg3tsguap's Avatar
thanks bruce your the man!
Old 02-19-2009, 10:40 AM
Dr Dave's Avatar
definatly the small amp then, and rear speakers??
hybrid...i love it
Old 02-19-2009, 10:42 AM
Sagar's Avatar
My Ride: 2006 523i M-Sport
Originally Posted by IceyTys' post='796695' date='Feb 19 2009, 03:48 PM
That is interesting information, THANK YOU.
I would be curious to know though if the frequency ranges stated above for each type of system is the frequency that is produced coming from the head unit, or just what the total speaker range by the speakers that can be reproduced??? I.E. is it limited by the head unit or the speakers?
If that is the figure coming from the head unit, that would mean if you have the standard HiFi or lower you could never really add any low end bass to your car (below 40Hz) unless you change the head unit. And if you have the standard EU system (>50Hz) you're really screwed even if you upgrade the speakers and amp if the head unit is the deciding factor
Think about it....if you by a 10-12" subwoofer how are you gonna get a low bass response if you never had a frequency below 40hz going from your line tap??
Thats where you need to add an equalizer. Most will "flatline" the eq curve from source (either the HU or Amp) and allow you to tune/eq the car to your settings. The better the eq, the more options you have to toy with frequencies, different speakers etc.
Old 02-20-2009, 04:30 AM
IceyTys's Avatar
Originally Posted by bruce_miranda' post='796790' date='Feb 19 2009, 10:28 AM
Now if I see another "Where are my speakers" type question I'll really loose it...
Attachment 72151
Bruce,
Once again you are the master... I think this 1st diagram answers my question with regards to the Ohms, as it seems the speakers (and not the HU) are the determining factor on the lower frequency response. 30Hz over 40Hz
I was hoping to expand on your "aftermarket sub woofers and amp DYI" and get your thoughts. Since I am replacing my rear deck speakers with higher power components I am a bit worried that the 25 watts from the HU will not be enough to really notice much difference or drive the new speakers, since the new components I am installing are RMS at 120w and peak at 160w.
I was thinking I can tap the rear deck speaker outputs (from the HU) into the factory HiFi amp as inputs then run new wires to the rear deck speakers from the factory HiFi. Do you think that would work? Id be a shame to let the old amp go to waste and the new deck speakers not be used more efficiently. I realize I may have more power to the rear with this idea, but I am sure during tuning I can just adjust some fader to the front to create a balance if the factory amp doesnt have any gain knob.
Your thoughts?
Old 02-20-2009, 05:14 AM
If the Hi-Fi amp was simply an amp then I cannot see why not provided you use Speaker to Line convertors. However if its done some fancy filtering and crossovers then you'll loose some stuff because the amp was not designed to amplify a non LOW signal. Also I don't know if there is any compromise in the design of the amp because it was meant to only amplify the non directional low freqs. But its worth a try and reporting.
I actually bought the L7 mids to put into my car but decided against it because I didn't want 40w speakers being driven by a 25W HU, contrary to what most people think you need to drive the speakers well for them to sound good or else you risk putting too much stress on the HU trying to drive a harder speaker.
Old 02-20-2009, 05:56 AM
IceyTys's Avatar
I actually bought the L7 mids to put into my car but decided against it because I didn't want 40w speakers being driven by a 25W HUcontrary to what most people think you need to drive the speakers well for them to sound good or else you risk putting too much stress on the HU trying to drive a harder speaker.
Agreed, thats what I thought too, which is why I am thinking of using the HiFi amp to drive these new rear deck speakers. The good news is the replacement speakers I am buyin are 4ohm so they should offer less resistance with the head unit trying to drive them, if my experiement doesnt work.
I will test the theory with the CD you pointed me too and let you know how it goes.
Old 04-18-2012, 12:39 PM
sd_dracula's Avatar
Can the pre-LCI M-ASK head unit with standard EU audio (6 speakers in all) power the L7 midrange speakers?
incoherent
04-15-2015 04:48 PM
james69z28
03-23-2015 06:45 PM
Guest_First Time Buyer
The Competition
12-06-2003 04:47 AM
08-12-2003 11:41 AM
06-17-2003 09:38 PM
Quick Reply: Difference between the sound systems offered
