Dension GW 500
Hello!
I know this topic is all over the place,
I've looked
However i can't find a definite answer on my question. 2004 530i without mp3, without CDC, first thing is to Install the unit, then get it coded for mp3 playback right? what about blouetooth? How does it work? This question for those who are using GW500 bluetooth: It mutes the speakers?
If some of you can take a second and respond to these questions i would greatly appreciate it!
Thank you
![Worthy](https://5series.net/forums/images/smilies/imported/worthy.gif)
Thank you
not sure if you already found your answer, but what I know, you'll need to have MP3 playback programmed, as well as CDC prep. I'm also still a little hazy on all this, but planning to get a Dension for Xmas, so I'll be trying to figure this out again soon, no doubt.
GL
GL
Administrator
GL
GL
Hello!
I've looked
Thank you
Thank you
CDC coded - YES or iPod MOST coded in. Without this Dension won't work.
Bluetooth - You will need the Bluetooth option coded into your car. It does mute the speakers.
Once you understand how the Dension works, it suddenly becomes clear what you need to do.
Dension is simply fooling the car to think that its a CDC/iPOD, Bluetooth or TV(for AVR). Thus if the car has any of those missing it won't work. Problem is that Dension thought that everyone had access to an Autologic garage that could simply turn options on. BMW dealers cannot turn options on without the modules actually being there.
The bright side is that the Dension annouces itself on the MOST as the iPOD, so if you can convince a dealer to code this as an iPOD kit then you will be good. But good luck telling them to code it as an ipod without actually having the ipod kit installed.
Need MP3 coded - Good to have but not absolutely necessary. Without it all you loose is track names on the idrive.
Thank you bruce_miranda!
Now i have to shop around!
I have just installed one, here in Aussie land, it is very hard to get the BMW dealer to do any programming. I found a local Autologic garage that had never seen a Dension and offered to program the modules for free if I showed him how to install the unit and how it worked.
Worked out great, as my car had to have both the ipod / blue-tooth modules programmed for the unit to work. I have installed an old 16g ipod nano (that no longer worked due to battery issues) and this now works great via the gateway section. The bluetooth again works well, in that it works as part of the car, lists all my contacts etc.
So best option I can see, is to find a Autologic garage ask them how much to do the Dension program (It is an option under upgrades) it took about 5 min to program but the system looks like it is going to do a full upgrade. However it only updates the code that is selected.
My next option is to install / fit the mic at a location close to the roof. I was hopping to use the existing wires however I can not find any doc's on what to use.
Hope this helps, I love the unit, as it gives the feel of a factory option.
If your in Adelaide SA - see www.bmconnections.com.au They can now do this program.
Regards,
Troy
Regards,
Troy
bestofthebest
03-28-2016 02:47 PM
wooboodoo
10-25-2015 02:58 PM
Bank$hot530
09-16-2015 01:28 PM
