Dension Gateway 500 installation
Ok just went through every single Dension thread (about 4 pages) trying to find out if anyone did a DIY on how to install the Dension 500 if you just have CDC prep but no CDC. Seems like no one did.
Car details:
BMW 520d E60 22.09.2005
MASK 6.5" radio, no sat nav, no BT, no CDC but CDC prep (cables in glovebox)
The dension comes with 2 fibre cables: 1 labelled "CDC side" and 1 labelled "Car side".
Since I have no CDC I assume I simply need to connect the 2 fibre cables from the glovebox to the "Car side" cable and plug that into the Dension, as per the image below right?
The "CDC side" cable will not be used correct?
Also I will be using an Autologic machine for the enabling, will the Dension need to be in Gateway more of Bypass/CDC mode?
Car details:
Yes I did exactly this more than 3 years ago ... so you probably not searching extensive enough, anyway the post 'bout my install:
http://forums.5serie...ndpost&p=725161
I didn't even use the fiber cables from Dension kit I simply re-use the pre-wired CDC (of course after re-arrange the factory jumper).
Not sure how in Autologic as I simply use OEM iPod interface to code it and of course the Dension must be in in Gateway mode if you put it in Bypass it'll not be seen.
GL!
GL!
Car details:
Car details:
Yeah that's it, my setup looks exactly like the OP's photo in that thread, see below. Thanks
One last question.
After I open up that black connector which loops the car's fibre cables together, I assume those 2 green car cables plug into the dension Car side cable which is circled below (2nd photo) right?
Or would I need to put the green cables in the same connector where the power cables for CDC are then plug into dension cable?
One last question.
Well, yes & no, after break out the black box you circled on the 1st pic then I just re-use the black connector end (on the right side of the pic) from Dension kit on your 2nd pic (after break it out too), as I mentioned previously I didn't even use the fiber lines that came from the Dension kit 'cuz having the fiber lines that are too long will just complicate storing them 'cuz you can not kink the fiber lines and the glove compartment don't have much room.
Just be careful w/ the directional of the beam or you'll get at least SOS warning (among others) lit up like X-mas tree on your iDrive.
One last question.
One last question.
Ah ok got it. So no point using the orange cable just plug the green car ones in the black connector of the orange cable and plug that into the dension.
If I supply power to dension and no fibre connected will it emit a red light so I know which port is sending/receiving?
My Ride: 2006 520d - 19" 172s- Remapped - LCI taillights V6 cables - LCI xenon headlights - Denison 500 with BTA1500 - led interior lights - OEM led number plate lights
Planned mods:
Folding mirrors - Modmynav kit - High gloss shadowline trim -
Sounds like you may have solved your problem but this was the DIY I used if it helps
https://5series.net/forums/topic/750...nt-have-a-cdc/
Also, check out page 7 of the below link outlining a MOST bridging connector, which you may need.
https://5series.net/forums/topic/715...d/page__st__90
Thanks jas. On the first link you put up it looks like there are 2 bridging MOST connectors (circled in red below). My car only has one and there aren't any of them in the Dension package.
Am I missing something?
'cuz that small black box that bridge the loop came from BMW not from Dension, why complicate thing ... by going w/ 2 bridge blocks you basically extend the fibers using the orange from the Dension kit and you'll run into storing the fiber (are you planing to put the Dension box away other than in the glove box?) otherwise just simply pop open all the ends and replace all done.
If you like to do it like the pic using 2 small black box bridges you can buy it at the dealer.
