Dension Gateway 500 + BTA1500
Hi,
Newbie here, I've been reading the forum for a few months with regard to installing the Gateway 500 and Bluetooth adapter. I finally took the plunge last week and purchased them, I had it installed by a local garage then took my car to an Indy garage to get the retrofit mp3 and Bluetooth module enabled.
I have a 11/03 model with business Nav single slot in main dash and cd changer in the glove box.
I was under the impression the any e60 could be programed to work so that you can see the text on the idrive screen. At the moment I can't read any text, menu still shows Cd1 to cd6, no other options available (iPod ui etc), I can control the iPod via the idrive but can only see track numbers.
With regards to the BT, I can now pair with my iPhone and stream music but I don't have any phonebook on the screen, I can receive calls and have caller id. To dial out I have to manually type the number through the idrive.
The garage that installed the software modules says that my car can't display text and that I would have to upgrade my MASK ( he said he checked the part number).
Any techies out there that can help? Can all e60's be programed to display txt or does it depend on the hardware?
Any help appreciated.
Dave....
Dave....
My Ride: 530 2005 E60
Originally Posted by Davy Mac' post='1027884' date='Oct 8 2009, 03:20 PM
Hi,
Dave....
Dave....
If NO. then you have to update the car to the latest firmware.
it costed med 2500:- Sek
As far as the text, My car is a 12/03 built and I have a Dension 500 with text display. My car still does not play MP3, but I see all the text from my iPod. First thing and probably the only thing you need to do is make sure you have the dip switches on the Dension set-up correctly. For me, having dip switch 1 and 2 up and the rest down is what worked for me, then all the options showed up. See this thread for more potentian help.
https://5series.net/forums/index.php?showto...71577&st=15
Hope that helps
Let me know how the BTA1500 works out as I'm planning on getting it soon without activating bluetooth in my car (programing) I want to know what it can do out of the box.
Thks
Greg
Hope that helps
Thks
Greg
Hope that helps
Thks
Greg
Hope that helps
Thks
Greg
if you can see the text but cant play the mp3 you need to upgrade the CD player
what you can do with the BLT 1500 out of box.
Stream music from phone and even run Spotify
answer the phone call from the phone. the onlything is that you cant use the idrive to call or asnwer the phone.
Im hoping toget my idrive programmed tomorrow.
bestofthebest
03-28-2016 02:47 PM
wooboodoo
10-25-2015 02:58 PM
Bank$hot530
09-16-2015 01:28 PM
