Custom Kidney Grill
Old 11-08-2008, 03:51 PM
jacobazizi's Avatar
I need my own OEM grill to be painted Platinum Grey Metallic, how much is a fair price for this process, and i heard my car will have to be noseless for a whole day.
Old 11-08-2008, 03:58 PM
radzM's Avatar
you can buy custom painted grills for about 100 I think.
Old 11-08-2008, 04:03 PM
Gene's Avatar
Where are you located? Perhaps a member close to you can recc a shop close to you for a good price. Make sure they strip the chrome off the grills before painting. A day would sound about right tho, just to allow the paint to dry correctly...GL
Old 11-08-2008, 04:19 PM
jacobazizi's Avatar
Im located in West Los Angeles, but I also work in Downtown LA, so either location works, n thanks guys.
Old 11-08-2008, 04:20 PM
PM sent welcome and enjoy the forums.
Old 11-08-2008, 04:31 PM
BALASUBAS's Avatar
and enjoy the forums!!!
Old 11-08-2008, 04:38 PM
tbal's Avatar
My Ride: See sig :)
1. Take grills off the car
2. using a 800grit sand paper, sand them down even so the chrome finish is no longer shiney. You may want to go lower grit, but 800s nice, may take longer, but will make it smooth.
3. Using a self-etching/bonding primer (sticks to plastic, abs etc) spray 2-3 coats evenly.
4. Allow to dry/cure overnight. (I know its along time, but this way you know if you will have no future problems of peeling, bubbling up.)
5. Inspect surface, if bubbles, ripples, drips, go back and sand that area, and re do another coat or 2 of primer.
6. Allow to dry
7. Using whatever color (In my case I used black duplicolor trim spraypaint) spray 2-3 coats of paint.
8. At this point go over the whole surface using a 1500-2000grit sandpaper, using "wet-sand" method. (keeping it wet and lubricated with soap at all times) DONT APPLY TOO MUCH PRESSURE
9. The surface yes wont be shiney at all, look scuffy etc... no problems! Using a laquer based clear coat (duplicolor) spray down a good 3-4 clear coats! This will make the color pop out, make it shiney and last a long time!
If anythings confusing holler... I am not affiliated with duplicolor, its just a good brand rofl. This is my own write up, so copyright tbal 2008. rofl jk
Old 11-08-2008, 04:40 PM
jacobazizi's Avatar
Thank you, I've only had gotten my 528i for a month, but im trying to do everything quick, ive done tints and roundels already, and i think grill are also a nice n cheap cosmetic enhancement.
Old 11-08-2008, 04:46 PM
jacobazizi's Avatar
6. Allow to dry
Thats wayyy too crazy for me to do, n plus im not that technical of a person, just want some local dealers
Old 11-08-2008, 04:50 PM
Gene's Avatar
6. Allow to dry
Nice write up tho tbal..should post that in the DIY section...
Quick Reply: Custom Kidney Grill
