Considerations in going to larger wheels...
I've only had my car for a week, and I'm already considering my first mod.... 19" OEM style 166 wheels. My car currently has the stock 18" sport package wheels w runflats. Not knowing anything about wheels and how they work, is there anything I need to consider? Will the OEM 166's fit properly on a 545i by just bolting them on, or is there something else I need to do? Will the different size wheels affect the speedometer/odometer readings, and does an adjustment need to be made to those? I notice that the 166 rear tires are wider than the front ones... is this a problem? What other questions should I ask the tech?
If anyone who has replaced stock 18's with 166 19's can guide me through it, I'd appreciate it. Thanks!
there's nothing wrong with a staggered set-up. you just wont be able to rotate the wheels. yes they will fit perfectly on a 545 but not with the tires of an M5. recommended tire sizes are 245/35/19 front and 275/30/19 rear. the offsets of the oem 166s i believe are front ET12 and rear ET28. they will fit, but if you want the rear wheels to be flushed with the rear fender, and for a more wider stance, you could add 12mm spacers. and also for a better ride, no more runflats. hope this helps.
So if I go with 245/35/19 front and 275/30/19 rear tires they will fit okay? Since I can't use the M5 tires, what brand/model of tire would you recommend. Can I get the 12mm spacers from BMW, or are they aftermarket. and are they needed on all 4 tires or just the front?
Thanks.
My Ride: 2004 530i
I also recommend lowering your car when you get new wheels..
My Ride: 07 BMW 525i Premium Package, Xenon Lighting Package, manual Transmission. Titanium Grey, 20% Tint around the back, 70% V-Kool on front.
Planned mods: Style 71 wheels with Toyo Proxy 4 tires, Sachs suspension upgrade, upgraded stereo, and many more to come.
Thanks.
Thanks.
Since you have sport package, you may get back without lowering it. Personally I won't lower it since although it looks nicer, it's quite easy to scrap the bottom of the front bumper... I don't have SP so it's almost a must to lower it with a 19" combo.
My Ride: 2007 E63 AMG | Obsidian Black | Schwarzes Nappa | Black BirdEye Maple | Premium II Package | Electronic Trunk Closer | Parktronic
Engine: RPi/Powerchips custom ECU tune, RPi Ram Air Kit (BMC filter, scoops), RennTech Sport exhaust, secondary cats, charcoal and resonator delete, custom AAA x-pipe
Exterior: 50% side windows / 35% rear window Formula One Pinnacle Series | Flat AMG hood emblem
Suspension: Renntech Lowering Module
Wheels/Tires: Radenergie R10, Falken FK452 245/30/20, Yokohama ADVAN Sport 285/25/20
2005 545i Sport SMG | Ti Grau | Schwarzes Dakota | Anthracite Maple | Logic 7 | Nav
Engine: Custom AFE CAI, Superchips ECU remap, Sprint Booster, RDSport Dual Exhaust Conversion with Quad Pipes and X-pipe, 3 resonators deleted, 90mm tips!
Exterior: M-Tech Aero kit | M5 Mirrors | M5 Rear Bumper | Trunk Lid Finisher | Vorsteiner decklid spoiler | 50% Formula One Pinnacle Tint
Suspension and Brakes: Bilstein PSS9 coilovers, JBT BBK: 16" cross-drilled rotors, 8 piston and 15" cross-drilled rotors, 4 piston
Wheels: VIP Modular VR 02 20x9F, 20x10R | Toyo T1R 245/30/20F, 285/25/20R
Lights: PIAA 4150K Xtreme White Plus fog lights, AIB v3
MOST IMPORTANT: Hardwired V1; =)
ED Date: 4/7/05, Re-delivery date: 5/21/05
If I were you just side step the 19" and go straight to 20" wheels.
My Ride: 2004 530i
Originally Posted by vegastrashed' post='472336' date='Sep 20 2007, 02:17 PM
If I were you just side step the 19" and go straight to 20" wheels. ![Thumbsup](https://5series.net/forums/images/smilies/imported/thumbsup.gif)
might as well
![Post](https://5series.net/forums/images/icons/icon1.gif)
Yeh i have 20in wheels, looking stunning on lowered eibach springs, however the ride is a bit choppy on bumby roads, otherwise no real concern
in the latest PBMW magazine this month i saw a E63 645i with 26in spinners....!!!!!!!!!
My setup (described below) is pretty standard, except that most get the 15mm spacers instead of 20mm.
Looking back, I think that 20" is the way to go to really make an impact, but my 19" wheels are nice too.
My Ride: No mods
+1 i got tricked tho.
