Comfort seat retrofit; switches not working
Old Feb 10, 2023 | 11:23 AM
neilv's Avatar
My Ride: E61 530xi 6MT
Engine: N52
Default Comfort seat retrofit; switches not working
Hi there, I just switched my E61 530 from the base seats (2007; memory + heated) with the comfort seats (2006; memory+heated). Through all my reading these should be plug and play (both harnesses had the same yellow plug with a separate smaller black one).
The drivers seat does all the way back and tilts all the way back everytime the key is put on/car is unlocked but other than that 0 functions on the switch for drivers & passengers work. Drivers seat heating does work; but I have not double checked the passenger. No error codes on dash or scanner. Also coded the VO (S459 to S456).
However I can use my schwaben scan tool and move the seat around; every function works for both sides. So the wiring must be right somehow?? Any ideas?
Old Feb 11, 2023 | 05:23 AM
neilv's Avatar
Engine: N52
On further inspection on the chassis side I have 4 wires at the black plug going to the module (power & ground plus the 2 can wires) and the yellow connector has 4 wires (2 to seat belt and 2 to seatbelt tensionner). But the Seat side of that connector has 3 extra wires which all go to the seat switch (guessing power/ground and signal).
Should these not be connected to the seat module like my previous seat was? some reading shows people connect these wires to the center console switch but why? My old seats were full power and memory and functioned from the can bus so is there an output on the seat module I can connect it to?
stecom90
12
Dec 13, 2021 08:08 AM
skeematics
Jun 6, 2018 05:33 PM
johneves
Jul 21, 2008 04:59 AM
dgjk
DIY: Do It Yourself
Oct 19, 2006 04:49 AM
Peter530i
Aug 4, 2005 11:57 AM
