Which Coilovers and why?
I'm planning on stiffing up the suspension of the 530i, especially since I got the 20's and I don't want it to rub when cornering hard. So, I'm thinking about getting the H&R Anti Roll Bars unless there are some that are better? Also, I'm thinking about getting either the H&R Coilovers or the KW V2 Coilovers, which of these two should I go with? Any suggestions, thoughts, and alternatives would be appreciated. Thanks.
My Ride: E60 M5, F85 X5M
I have the KW V2 coilovers and I love them. I'm unable to give you a comparison between the KWs and H&Rs since I've only used the KWs. Freed0m also has the same KWs as mine.
I guess only if you're lucky enough to find them on the classifieds or something. The guy I bought it from only had that one set. I would also check the classifieds on Bimmerfest.
