Coilovers fit 530 work for 550?
http://www.autoanything.com/suspension-sys...A0A2491173.aspx
I MIGHT be picking these up but I have a simple question. When buying springs, there are different ones for 530 and 550 due to weight. Does this still apply to coilovers? The link above only says it works with e60, but doesn't specifically say it works with 550, anyone have input?
Originally Posted by Rizbel' post='375604' date='Jan 9 2007, 03:27 AM
If you go with KW, get the three stage version, variant 3 or V3. You can adjust the damper and the ride height indepedently.
KW's website lists the same coilover for all E60 applications except M5, and same goes with Bilstein. So it should work.
CertifiedOfficial
04-18-2015 12:11 AM
