Coded some extra menu options.
Old 12-16-2010, 11:25 PM
  #71
tonyflow's Avatar
Cool, how much would you want to do all that?
Cheers.
Old 12-18-2010, 04:52 AM
  #72
///MrSingh's Avatar
My Ride: 2007 E60 535d M Sport
Originally Posted by BLooD
If you have BMW assist then I can retrofit BMW online no problem. corner lights might work or they might not. I can add a digital speedo to the cluster and I can make the alarm chirp when you unlock/lock.
Kerb function does not and I repeat does not need memory seats, I wish I had a pound for every time I have had to repeat that.
High beam assist needs the extra light sensing camera under the rear view mirror.
What needs coding for BMW Online to function Blood? And do you need to have an active subscription to BMW Assist for it to work? (My trial one ran out a while ago).
Also did not know about the mirror dip function not needing memory seats, very interesting info...
Old 12-18-2010, 04:55 AM
  #73
BLooD's Avatar
For BMW online you will need an active assist account, Add $616 to the VO then code the TCU and CAPPL with the standard expert profile.
Old 12-18-2010, 05:50 AM
  #74
AlexFW's Avatar
Model Year: 2005
Just found the option to enable the M heads up display.
Useless, I enabled it and immediately disabled. And you lose the second button on the steering, as the M5 doesn't have it.
About the Mview on HUD, it works from 2006 cars.
By the way, it's possible to activate the Mview (on every E60) if you have the M5 cluster.
Old 12-18-2010, 05:56 AM
  #75
AlexFW's Avatar
Model Year: 2005
Originally Posted by irony
Anyway we can get the M Rpm HUD display?
Yes.
Old 12-18-2010, 05:59 AM
  #76
///MrSingh's Avatar
I tried this, didn't work for me - I have a December 2006 car. Once it's enabled can you switch between normal and M-HUD?
  #77
AlexFW's Avatar
Model Year: 2005
Originally Posted by bruce_miranda
What people here are doing are using factory level software that allows changing of variables at an individual module level.
Exactly.
Old 12-18-2010, 06:01 AM
  #78
AlexFW's Avatar
Model Year: 2005
Originally Posted by Randuin
How can someone get started with all this coding stuff?
It's not easy: you need a few months on bmwecu forum (but you can't register to it now).
Old 12-18-2010, 06:02 AM
  #79
BLooD's Avatar
Im self taught, I have never been to bmwecu.
Old 12-18-2010, 06:03 AM
  #80
AlexFW's Avatar
Model Year: 2005
BenAnd: just 30 seconds for you.
From MY2006 always active. For old cars Mview should be possible with M5 cluster. I didn't retrofit the HUD yet so can't try, but I was told in this way by a Russian guy (very very very skilled).
Quick Reply: Coded some extra menu options.
