Coded some extra menu options.
#31
My Ride: BMW e60 525IA 12/2003
Hi
High Beam assist was first a option on the E60/61 from Sept. 2005 , but can with out any problems be refitted to E60/61 pre Sept. 2005 , I have done it on my Dec. 2003
It only takes the Mirrow with the FLA camera and a coding.
#32
BenAnd any ideas how to get SA430 auto dim mirrors working?, I have retrofitted the mirrors, got the puddle lights working, got the mirror controls and heating working, Mirrors fold in and out but I can not for the life of me get the auto dim working.
#34
Hi
Att: BLooD , regarding the outside mirrow's aut. dimming function , you will have to be sure that you have them connected to the inside back mirrow , due to it is that , that controls the dimming of the outside mirrow' , please look it up in the BMW WDS. ( you must have either 2 wire's form the inside mirrow to each of the outside mirrow's , or from the door modul ( HIGH ) to each outside mirrow
, depending of the prod. date of the car ).
Att : tsaros , please look up the thread elswere here on the forum regarding this issue
Regards
BenAnd
Regards
BenAnd
#35
BenAnd I have just looked at the WDS, On my E60 I have no door modules and the mirrors are connected to the body gateway module (KGM) on pins 14 and 23 (lin bus connection) plus 2 cables goto to the interior mirror from pins 44 and 45 of the body gateway module (KGM) plus one from the interior mirror to the light module.
#36
My Ride: 2008 BMW 550i Silver Metallic w/Sport Automatic Transmission, Ventilated Comfort Seats in Beige Nasca Leather, Light Poplar Trim, NAV, HUD, Active Steering, Night Vision, Active Cruise Control, Logic 7, Blue tooth Hands Free, Dynamic Stability, Soft Close.
Mods: RPI Exhaust, Scoop + FIlter, License plate LED lights
Anyway we can get the M Rpm HUD display?
#39
Hi BLooD
I know this sound stupid
, but I have to ask you , do you have the right outside mirrow-glas mounted ? the type with 4 wire's comming out from each mirrow-glas ? ( +/- for heating & +/- for dimming ), the purple and black ( if I remember right ) must go to the KGM modul ( or alternativ direct to the inside rearview mirrow , to witch pin's you can see in the WDS ) , the outside mirrow's only dime together with the inside rearview mirrow , it is this that gives the "command" to the outside mirrow's regarding to dime , but I gess you allready know's that ?
Regards
BenAnd
![Cool](https://5series.net/forums/images/smilies/cool.gif)
Regards
BenAnd
#40
the basic mirrors fitted had 4 wires going to the KGM module, I got some SA430 mirrors from a 2008 car, these have 3 wires, red for live,. brown for ground and green for LIN bus. Theres a small control module inside the mirrors, all functions work just fine except the auto dim.
