CIC Retrofit Installation LOG
Old Jul 19, 2010 | 06:06 AM
  #241
pclausen's Avatar
My Ride: 2006 M5 w/ all options
From a link from Nelson's thread on the m5board:
http://www.bmwpassion.com/forum/show...&postcount=117
So the 4 pin connector that connects to the Menu or Menu/VC button(s) is no longer used. However, we need to pull all the wires out of it, because we need the connector itself for the new controller.
So the following wires needs to be moved from the old 8 pin connector that went to the old iDrive controller to the donor 4-pin connector used to connect to the new iDrive controller:
Old - New - Function
1 ---- 1 ---- 12V
2 ---- 2 ---- GND
4 ---- 3 ---- CAN_H
5 ---- 4 ---- CAN_L
The wires that went to pints 3, 6 and 7 on the old controller are not used with the new controller, no are any of the 4 wires that went to the Menu/VC button.
I have not actually done this yet (hopefully I'll be able to try this tomorrow or Wednesday when my new controller shows up), but I'm pretty sure this is what needs to happen to get a new iDrive controller working in an E60 with the old controller (which I think is all models through 2008).
Old Jul 20, 2010 | 04:02 PM
  #242
pclausen's Avatar
Got my interface cable today and had about a 1 hour session with Patryk.
In about 20 minutes, he had my original iDrive controller working!
Apparently the dealer did upgrade the firmware/software on it, but for some reason, not well enough!
After another 20 minutes, he had my CIC reading CDs and DVDs, and after I checked that everything was working correctly, he programmed my mirrors to fold up when locking the car, and fold down when unlocking. Very cool!
I also have the new iDrive controller, and while the bracket for it does bolt up nicely to my existing console, the controller itself will not work with trim used for the original iDrive controller. I'll post pics in a bit showing the issue.
In short, the CCC to CIC conversion works great in pre-2010 M5s with no need to replace the original iDrive controller!
HUD, M5 button settings, everything works as it should, only much faster and nicer looking than before.
I give a big thumbs up to Patryk in being able to get my controller going where the dealer program update couldn't!
I'll post additional details later tonight. I'm very excited to finally getting the old iDrive controller working. I'm a bit dissapointed that my current trim won't work with the new controller, but I don't really have any issues navigating the CIC with the existing controller at all.
Currently in the process of loading the 2010 North America Nav DVDs.
Old Jul 20, 2010 | 04:32 PM
  #243
pclausen's Avatar
Here's the new iDrive bracket fitting perfectly into my console:
The new iDrive fitting not so perfectly below my trim:
Screen after putting in Nav DVD 1:
Entering the code:
Loading process started:
It better hurry up loading, my next mod is already here!
Old Jul 20, 2010 | 05:03 PM
  #244
Georgieb's Avatar
My Ride: 2007 Black Sapphire 535i
Congrats Peter!! It's great to see your success. I wonder if the dealer upgrades are even necessay given Patryk's accomplishments with programming. I'm still not able to get my updates done here in TO through the dealer.
Also by the looks of it the cavity from the old controller is larger than the new controller. This is not good news. I've ordered another pre LCI panel that I was planning on mod'ing too. Hmmm, maybe if we want to use the new controller we'll have to buy the LCI shifter trim and ashtray etc.
How did things work out with your climate control module? Did the dealer firmware upgrades fix that or did Patryk??
Old Jul 20, 2010 | 05:19 PM
  #245
Masterspy's Avatar
My Ride: 530I Silver gray with gray leather with Premium Package, Logic 7 Premium sound system with Ipod interface, xenon adaptive headlights, Active steering, Power retractable rear sunshade, Comfort seats, Cold weather package and M5 OEM 166 wheels, Sprintbooster. Ceramic Tint all around, Bilstein Sports shocks with Eibach springs, Brake performance Rotors and Axxis ceramic pads.
Entering the code:
I am seriously looking to upgrade to CIC myself and I have been monitoring the progress you guys have been doing. Congrats!!!
Are you still considering on going with the new i drive or staying with the old one? How long is the total time involve with the downloading all the necessary firmware/software with Patryk?
Old Jul 20, 2010 | 05:32 PM
  #246
pclausen's Avatar
My old iDrive is working great with the CIC, so I'll likely stick with it for the forseeable future. I'll need to decide what I want to do with my interior (convert to aluminun or carbon fiber or stay with wood) before making a move.
Depending on the state of the donor CIC, I'd say it would vary depending on what would need to be updated. It only took a few minutes for Patryk to download the software for my controller. This was over a 20Mbps fiber (FTTP) connection, so it would depend. The actual transfer of the binaries is not really what takes the longest. I would say the coding itself accounts for 75% of the total time it takes, maybe more, depending on what issues are encountered.
Old Jul 20, 2010 | 05:40 PM
  #247
nelson29's Avatar
My Ride: 2005 530i Silver Gray/ Gray Leather. SP,PP
Congrats again Peter. Glad Patryk was able to sort out all the issues and also glad that you were patient during the whole process.
Regarding the controller, I'm pretty sure there's a way to make it fit, we have the Italian M5board member as an example that it can be done. If for some reason it's not possible I suggest to leave as it is and use the old controller.
@Nigel-
The idea of getting the lci center trim and other lci parts should not be options specially for you guys that have wood trim. Believe it's very expensive and it's totally not worth it.
I been using the old controller for the past month or so and it works fine.
Old Jul 20, 2010 | 05:41 PM
  #248
Masterspy's Avatar
Thanks, I believe I will stay with my current idrive.
Old Jul 20, 2010 | 05:53 PM
  #249
nelson29's Avatar
I'm pretty sure Peter meant old idrive control with the CIC( new idrive )
The difference is night and day
Old Jul 20, 2010 | 06:55 PM
  #250
Georgieb's Avatar
Yeah Nelson, it does seem a little nuts to change all the additional trim required. I guess it's a matter of form vs function.
Do you know if Peter got his AC Climate Control working correctly?
