Choosing rims for: 530i vs 535i
I want to order Breyton Race GTS rims for my 2008 530i
TireRack only has a 535i model.
Do you think there is any difference between 530i and 535i ?
Here's the wheel info from their site (just in case)
18"
Offset: +35mm
Backspacing: 6.06"
Bolt Pattern: 5-120
Rec. Tire Size:245/40-18
Weight: 22.0lbs.
18"
Offset: +35mm
Backspacing: 6.06"
Bolt Pattern: 5-120
Weight: 22.0lbs.
As long as it is not xi you can use any kind of wheels regardless of model number...
isnt offset too high though?
i was looking at one from tirerack as well for 19" and it gave 35mm .
i think it needs spacer...
does anyone with GTS did you have to use spacers?
They wont fit, well they will on a 3 series!
Rears you can run 35 offset, but fronts max is like 25mm
Find wheels that are hubcentric and that have offsets from 15-22
The Oz Rims listed there had 21 offset for their staggard setup
so why do they say that they fit?
(i don't want any other rims except those)
Originally Posted by Kuat' post='796943' date='Feb 19 2009, 11:29 AM
the offset info is taken right from their website
what's a spacer btw?
I just got a reply from tire rack.
Are they bullshiting me?
Hello, Thanks for your email. Yes these will fit fine. I would recommend call me directly so I can ensure what you order is a good fitment.
Regards,
Rudy
Regards,
Rudy
Wow really, well its not surprising all their test cars are 3 series. The front will work you have to get a hubcentric spacer from H&R along with longer wheel bolts, I am sure nerweezy could get you that info, Its been a trend lately I have seen where wheel people are pushing the wrong stuff on to customers, I gotta find that link where a member like your self bought the rims from a supplier that said would fit and he put them on, and because the offset wasnt right the strut took out the outer edge lip of the rim.
