View Poll Results: Which rotors are better?
Voters: 14. You may not vote on this poll
Centric vs R1 Concept
I am getting replacement OEM-size rotors and pads. Need the most track performance and good road performance combo - I "track" occasionally, and am planning to do it more and more in this coming season. With OEM brakes had a LOT of fading issues, so I'm glad that the time has come to change the brakes finally.
Torn between two different rotor brands - Centric and R1 Concept. Which one of them, would you say is the better rotor? Cast your vote above, explain away below - would love to hear as much as you can spare to say! Weight plays a big role for me as well - its a NA 6 cyl car, so unsprung weight has to be kept to the minimum. Am planning to get the drilled/slotted ones.
For pads I'm between Hawk and Stoptech, but leaning toward Hawks, since I was just told that they are the SCCA's "pad of choice"
That's about right, yes.
How many miles you got on them so far? Any more in-depth comments?
From my research so far, seem like both Centric and R1 Concepts start out as the same rotors, but R1 does their own drilling and slotting, which - apparently - results in a higher price
but is it worth it???
![Wassat](https://5series.net/forums/images/smilies/imported/wassat.gif)
anyway, I've been researching this all night now, so I probably should give myself a little break
Thanks for the PM, Nerwyll, I'll be looking forward to the quotes
