center wheel ring
My Ride: 2006 530i sport/premium package, Black and Tan
2000 528i premium package, Black and Tan
![Question](https://5series.net/forums/images/icons/icon5.gif)
I purchased a set of aftermarket 18" E65 replica rims with Dunlop snow tires for my E60. I just installed them on my previously smooth running 2006 E60 530i. However now the car shakes and vibrates. I took it in for a balancing however the dealer said the problem is that the center wheel ring on the E65 rim is too big for my E60 and that is what is causing all the shaking and vibration. They wouldn't tell me what size spacer ring I would need or where I could find ones. Has anyone experienced this problem?
My Ride: Mini Cooper
you will need to buy 4 hub cantering rings to fit each wheel and they should be the same size.
all 4 wheels on my car have the ring which the shop put in when I installed my ACS 19"
I don't know the size but I try and find out tonight and let you know.
the best thing is just take it to a local shop and get them to add the hub centering rings.
Originally Posted by pinguhk' post='732468' date='Nov 26 2008, 08:36 PM
did you get the wheels on the net?
My Ride: 05 545/6
Now, replica wheels don't have to conform to anything, so they typically make them to the larger 74.1 and make everyone else get hub rings. one more reason I prefer OEM or wheels like BBS that have centering rings that mount inside the wheel and stay there thanks to a clip, so you don't have to worry every time you take the wheels off the car.
Thanks to all of your replies. I took it to a Firestone shop that specializes in custom rims. His book showed that the 530i was supposed to be 74.1mm for the hub ring but surprisingly found that it was the smaller 72.56mm. He had the wheel centering ring (plastic) in stock and now it runs great. Thanks again for the feedback!
My Ride: 05 545/6
TexaZ3
05-06-2015 09:54 AM
BrandonSS
03-13-2015 12:19 PM
