CAN THIS TRUE? Must read
My Ride: 2006 530i automatic, Active steering, sport package, Sirius,Active head lights, black on black, Maya DTR 20x9"frnt 20x10"rear wheels polished- 245/30-20 frt 274/25-20 rear. comming soon= H&R sports line spring or better. window tint and hp tune if out there
I Just called the BMW dealer to get a price on installing a set of Lowering springs on my 2006 5301 with active steering and sports pakage. Well, I have done this on many, many cars myself. One hour each spring max. Here is the punch line, The Dealer tells me it's 11 hours and that it will cost me $1100.00 plus if I want to do the alignment thats another $380.00. Well, after I pick my jaw off the floor I now have to Make a choice. I need some info from thoughs of you that have lowered their cars. Whats the big deal with the new 530i? I run a car dealership out here in San Diego CA and have never heard of a lowering job costing so much.. By the way I have 245/30-20 front and 285/25-20 rear. How much can I lower without rubbing? spring? shoks? or both?. Want the ride to be a smooth as posible. Thank guy or gals
My Ride: G30 M550i
Model Year: 2018
I don't have any real experience with lowering but isn't the concept of "lowering" and the phrase "ride as smooth as possible" a bit of an impossibility and an oxymoron?
yes, and in addition. It will probably take the dealer 4 hours to do it but the jobs all have their own time scale. IE an oil change might be scheduled to take an hour by BMW's standards but it will probably only take the tech 1/2 hour. And in order to tell you whether or not you will rub, and you lowering the car...offset is key.
If I were you I'd find a reputable aftermarket shop.
Heck, if you can find a lift, I'd be happy to do the install for you in exchange for a bottle of McCallen and some cubans ...
As to the drop, depending on your offsets, I think you can safely drop about 25mm without worrying too much about rubbing.
My mantra is always ... if you swap out springs, then you should swap out shocks as well. Or just do coilovers.
My Ride: e60 530i - SOLD!
Suspension retrofit ie. removing and changing shocks and springs plus wheel alignment take at least 4 hours with two chaps helping each other! Pretty tedious job!
Note that shock strut needed to be dismantled to replace spring as well. No short cut!
$1100 of labour is ridiculous to change the springs. I paid 4 hrs labor to change my springs.. Just find a reputable bodyshop near your area.. They should be able to do a good job
My Ride: Numero Uno in Richmond Va 04 530 6 speed, jet black, black dakota leather, xenons, red rear reflectors, 545 front grill, cold weather package, premium package, staggered 19 inch BBS rxII/michelins, H&R coilovers and intergrated, R1 concept drilled an
Engine: 530i
http://forums.e60.net/index.php?showtopic=18401
That is about the going rate they were going to charge me around 2000.00 dollars so ia asked the Sa about the back door price they chagrged me either 400 or six hundred including the alignment as i got the tech to do it at the dealership on his own time worked out great for me
My Ride: '04 545iS 6 spd, bought new via eBay, 11/05; Blk/Gry, Cold, L7, PDC, BMW Rear seatcover for pets.
First "Bumwa" was a new 1971 2002. High performance 5s since 1987. Beamer motorcycles too, currently on an 07 BMW K1200 GT; also a Moto Guzzi 1000 SP III.
That's not so bad: My local dealer wanted $300 to hardwire my Valentine 1. It's called gouging what the market will bear. Just hope you don't run into warranty troubles later on...
Ray Hull
Ray Hull
TexaZ3
05-06-2015 09:54 AM
