Can Someone help me with how to install LED fogs on my E60?
Old Sep 21, 2012 | 01:28 AM
Nicholast's Avatar
Hello everybody,
Just looking at installing some LED foglights on my 2005 BMW 525i E60 and was wondering if any one had a step by step procedure or pictures/ video on how to do it?
Also can I confirm with someone are they H7 bulbs?
thanks, all help is appreciated!
Old Sep 21, 2012 | 03:22 AM
sd_dracula's Avatar
They are HB4/9006 and you kind of need to get under the bumper to drop the plastic tray to remove them.
Also you will get errors all over the dash unless you use resistors or code out errors.
Old Sep 21, 2012 | 04:35 PM
Nicholast's Avatar
Thanks for the help I'll order some asap, any that you would recommend?
Is it hard to use the resistors/ do you know how to do the code out errors?
Using canbus LED HB4/9006 bulbs wont help will they?
Old Sep 23, 2012 | 11:24 AM
PhilGT2008's Avatar
This should help
https://5series.net/forums/topic/591...light-install/
Old Sep 23, 2012 | 12:17 PM
sd_dracula's Avatar
LED bulbs are just for show, you won't get any light off them (not light that you can use even in fog)
You're better off doing what myself and a few others on the forums have done, and just install a set of HID bulbs.
Looks much cleaner.
Old Sep 23, 2012 | 01:04 PM
C_o_s_m_i_n's Avatar
And if you need efficiency, let it be 3000K xenon.
socale39
Sep 5, 2023 08:30 AM
Kasmo
May 7, 2019 03:30 AM
tnycman
Jun 17, 2015 11:35 AM
mishka69
Mar 20, 2015 01:26 PM
ZeZe
Oct 15, 2003 12:58 PM
