Camber Kit Suggestions
I have an 05 non-sport e60 that I've installed eibach pro kit springs on. Now I'm going through tires like crazy. Do you have a camber kit that you would suggest? What can I do for the rear?
My Ride: Original E60 Spec:
530i - Silver Grey Out, Black Dakota Leather In, Navigation Pro, Voice Command, HiFi Audio, Sports Package, Premium Package, Cold Weather Package w/ Heated Seats, Style# 123 Alloy Track Wheels, Auto AC, Power Front Seats, Active Turn Xennon Headlights,
Mods:
OEM M-Tech Front Bumper, OEM M Side Skirts, OEM M5 Rear Bumper, M5 Trunk Lid Finisher, M5 Style Mirrors, Custom Hamann Style Splitter, Custom Hartge Style Diffuser, RD Sport Boot Spoiler, LCI Taillights, Bruce Miranda's V4 LCI Retro Cables, 6000K Xenon light Bulbs, Xenon White LED License Plate Lights, 8000K HID 9006 Fog Lights, Akalius� Front Headlight Euro Overlays, Matte Black Kidney Grilles, E60.Net Clings, Debadged, Llumar Tinting "Micro Edged, 15% Rear 35% Sides,
Engine Mods:
Custom Magnaflow Quad Exhaust w/ Eisenmann Stamped 3� Tips, RPI Scoop (Red)
Added Electronics:
V1 Equipped (Hardwired), OEM Alpine CD Changer Retrofit,
Shoes:
SOLD-20" Staggered Vertini Hennesey Rims, Falcon 452's Tires-SOLD
New Shoes:
19" VMR 710 Hyper Silver, General Exclaim UHP 245/35/19 Front-275/30/19 Rear, Gloss Silver Caliper Paint Job DIY
^_____________
Retired
______________
Took Delivery 10/26/2009: LOADED! E60 M5 Silverstone II/Black, Active Seats, Comfort Ventilated/Heated Seats, HUD, Brushed Aluminum Trim,
Is it necessary to install a caber kit if your car is lowered to avoid exceeding tire wear?
Also, there are different types of camber kits, such as upper strut mounts and the other which is a bearing mounted behind the hub on the lower control arm, correct?
Phi, to answer your questions: No you don;t always have to install a camber kit, although you are more likely to need it when you install lowering springs only instead of coilovers. Yes, there are 2 different types of kits, but as far as I know they only make the camber kits of the type I linked for our cars. Some coilovers come with camber kits on the upper mounts, but not for our cars (KSPort for example). That leaves us with one choice, lower camber kits.
Probably before deciding to get a camber kit you are better off getting an alignment done and seeing how much negative rear camber they can dial out of your car (BMW spec is 1.5-2.0 deg neg rear camber as I recall). If you have just lowering springs you will notice much more negative camber than with coilovers, I know I did when I went from H&R springs to full KSport coilovers - even without an alignment the negative camber was greatly reduced.
Mods:
Engine Mods:
Added Electronics:
Shoes:
New Shoes:
^_____________
Retired
______________
Probably before deciding to get a camber kit you are better off getting an alignment done and seeing how much negative rear camber they can dial out of your car (BMW spec is 1.5-2.0 deg neg rear camber as I recall). If you have just lowering springs you will notice much more negative camber than with coilovers, I know I did when I went from H&R springs to full KSport coilovers - even without an alignment the negative camber was greatly reduced.![Thumbsup](https://5series.net/forums/images/smilies/imported/thumbsup.gif)
To the OP, sorry if I thread jacked, just wanted some clarification on the different options available.
My Ride: 2004 530i
premium package/active steering/auto sunshade/tiag/black dakota leather/logic 7
35% tint all around
19' DPE GT7
I have the H&R sports which are about the same drop as eibach prokit and when the dealer did the alignment they said it fell well within factory specs so you shouldn't need a camber kit
houbmw
07-16-2015 05:48 PM
PelicanParts.com
07-16-2015 01:12 PM
