Breyton wheels question
I'm new to this forum so if this question has been asked already I apologize in advance. I have a opportunity to purchase 21" black Breyton Spirit and I was curious if there would be any fitment issues. I have 525i with sport package. I know the 21" will work on the M5 but it does have larger front fenders and requires spacers. I believe the tires they use on the M5 is 30series front and 25series back
Thanks in advance RLM
My Ride: ACS 745i, M-Tech 545i
21" Should fit on the E60, the good setup for that will be 21x9 w/ et23 and 21x10.5 w/ et28 like the BBS RX2. The 21" Breyton Spirit has a really aggressive offset 21x9 and 21x10.5 with et11 offset. E60 M5 is basically has the same rear fender as regular E60. The only different is on the E60 M5, the rear fender has been rolled all the way from factory. If you rolled your rear fender then 21" Breyton Spirit should fit on the rear but the front will not since the front fender is totally different between M5 and regular E60. Hopes this will help....Good luck....
Please post some pic. if you are able to put on that wheels....
srogers535x
14
04-26-2015 09:39 AM
