Brake pad sensor
How do you chnage the the brake pad sensor on the E60? One part of the sensor goes into the pad but where does the other end of the sensor go? is it an easy job?
When the pads are changed, the sensor will and must be changed at the same time!
The iDrive (pad sensors) tells you when the pads have to be replaced.
UltimatePeter
DIY: Do It Yourself
09-28-2015 09:12 AM
TexaZ3
05-06-2015 09:54 AM
